Wait until press button (execute only once)
Hello! I'm developing a program in which whenever a value from a sensor is exceeded a window appears on a TFT screen with a warning! The thing is, I want that window to hold (execute only once) while a button is not pressed. If the button turns to HIGH, then the program will execute again showing the new readings. My question is only about the structure of while/do/if...
I'm having problems on doing that..any help?
It's a preety basic code!
I have defined all the funtions that I wanted to make the warning window (funtion warning()).
Let's say I want to read out the temperature... in this case the code will be like:
if(temp>25){
    warning();
       //while button not pressed, warning() executed just once (so that the window won't be always blinking) and wait for buttonState==HIGH! After this, it exits the loop..
I know it has something to do with lastButtonState and so on..that's not the problem for me.. I'm just not visualizing the structure that I need to achieve this..
Here's the code. I know there are some things missing, but that's not important for me right now..
#include <TFT.h>  // Arduino LCD library
#include <SPI.h>
// pin definition for the Uno
#define cs   10
#define dc   9
#define rst  8
TFT screen = TFT(cs, dc, rst);
// position of the line on screen
int xPos = 0;
int offset=40; //offset vertical position graph
int graphHeight=40;
int RLux=10;
const int buttonPin=2;
int buttonState = 0;
int lastButtonState=0;
int standby;//standby Power (W)
int standbyGraph;
char t[3];
char l[5];
char p[6];
  pinMode(buttonPin,OUTPUT);
     // initialize the display
  screen.begin();
  // clear the screen with a pretty color
  screen.background(204,229, 255);
  // initialize the serial port
  Serial.println("Choose your standby Temperature (Power):");
  while(Serial.available()==0){
  screen.stroke(0, 0, 0); //posso meter isto dentro da função createSquare
  screen.setTextSize(2);
  screen.text("Go to \n Serial Port", 12, 40); //Texto -7 nos yy
  standby=Serial.parseFloat();
  delay(2000);
  createSquare(0, 9);
  screen.setTextSize(1);
  screen.text("Power (W)", 2, 2); //Texto -7 nos yy
  createSquare(0,95);
  screen.text("Lux", 2, 88); //Texto -7 nos yy
  createSquare(82,9);
  screen.text("$", 84, 2); //Texto -7 nos yy
  createSquare(82,95);
  screen.text("Temp. (C)", 84, 88); //Texto -7 nos yy
  int sensorVal0=analogRead(A0);
  int drawHeight = map(sensorVal0, 0, 1023, 0, graphHeight);
  float volt0=(sensorVal0*5.0)/1024.0;
  float current=volt0*10.0; //max current = 50 A
  int power=current*230;
  String PowerVal=String(power);
  PowerVal.toCharArray(p,6);
  // read the sensor and map it to the screen height
  int sensorVal1 = analogRead(A1);
  float volt1 = (sensorVal1/1023.0)*5.0;
  int temp=(volt1-.5)*100;
  String TempVal=String(temp);
  TempVal.toCharArray(t,3);
  int sensorVal2=analogRead(A2);
  float volt2= sensorVal2*0.0048828125;
  int lux = 500/(RLux*((5-volt2)/volt2));
  String LuxVal=String(lux);
  LuxVal.toCharArray(l,5);
   //valores todos escritos aqui!
  screen.setTextSize(3);
  screen.text(l, 2, 102);  //Show Lux
  screen.text(t, 102, 102); //Show Temp
  screen.text(p,2, 16); //Show Power
  screen.text(t,102,16); //Show Cost
 if(lux>500){
   warning();
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
     //WANT TO EXIT LOOP
    else {
      //STAY IN THE LOOP, REPETING WARNING JUST ONCE
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  if(temp<=standby){
    screen.stroke(0, 230, 0); //GREEN
    screen.line(xPos, offset+(graphHeight - drawHeight), xPos, offset+graphHeight);
  else{
    screen.stroke(255,0, 0); //RED
  if (xPos >= screen.width()) {
    xPos = 0;
    //screen.background(255, 255, 255);
  else {
    // increment the horizontal position:
    xPos++;
  //LIMPAR TODOS OS VALORES (clean all values)
   createSquare(0,95);
  createSquare(0, 9);
  createSquare(82,9);
void createSquare(int x0, int y0){
 screen.stroke(255, 250, 100); //YELLOW
 screen.fill(255, 250, 100); //graph's rectangle background YELLOW
  //square da Temp.
 return screen.rect(x0, y0, 78, 33);
void warning(){
  screen.noFill();
  screen.stroke(0, 0, 0); //RED
  screen.rect(10,40, screen.width()-25, screen.height()-60);
  screen.fill(255,255,255);
  screen.stroke(255, 0, 0); //RED
  screen.rect(11,41, screen.width()-27, screen.height()-62);
  screen.text("AVISO",25,45);
  screen.textSize(1);
  screen.text("Lux Limit Exceeded",35,55);
Thanks for the hint!
I managed to do something like this:
int start_click=LOW;
 if(lux>500){
      while(!start_click){
      start_click = digitalRead(buttonPin);
      warning();
      Serial.println("Waiting for button press");
The problem is that the warning window is always blinking..can you help me with this? I wanted to execute warning just once
