Hi everyone,
I am working with code from the SDfat library under examples v1 > lowlatencyloggerMPU6050. There is a section of the code that calls a function to open the bin file created but asks for input of the number first.
I made some changes albeit not as elegant as the original program to add a button press to start and stop the recording part of the program:
Here is the code for my loop:
void loop(void) {
buttonState = digitalRead(buttonPin);
// Check if the button state has changed
if (buttonState != lastButtonState) {
// If the button was pressed (change from HIGH to LOW)
if (buttonState == LOW) {
toggleFlag = !toggleFlag; // Toggle the flag
delay(50); // Debounce delay
lastButtonState = buttonState;
if (toggleFlag)
ledState = HIGH;
digitalWrite(ledPin, ledState);
//testSensor(); // function is ON, call the function
logData();
else {
if (textPrinted == false) {
menuSelect();
selectOption();
void menuSelect(){
if (!textPrinted) {
Serial.println(F("type:"));
Serial.println(F("b - open existing bin file"));
Serial.println(F("c - convert file to csv"));
Serial.println(F("d - dump data to Serial"));
Serial.println(F("e - overrun error details"));
Serial.println(F("l - list files"));
Serial.println(F("t - test without logging"));
// Reset the textPrinted variable to allow printing the text again
textPrinted = true;
void selectOption (){
char c = tolower(Serial.read());
// Discard extra Serial data.
while (Serial.available() && Serial.read() >=0);
if (c == 'b') {
openBinFile();
} else if (c == 'c') {
binaryToCsv();
} else if (c == 'd') {
dumpData();
} else if (c == 'e') {
checkOverrun();
} else if (c == 'l') {
Serial.println(F("\nls:"));
sd.ls(&Serial, LS_SIZE);
textPrinted = false;
menuSelect();
else if (c == 't') {
testSensor();
I am calling the openBinFile which asks for a two digital character input. Here is the original code:
void openBinFile() {
char name[FILE_NAME_DIM];
strcpy(name, binName);
Serial.println(F("\nEnter two digit version"));
Serial.write(name, BASE_NAME_SIZE);
for (int i = 0; i < 2; i++) {
while (!Serial.available()) {
yield();
char c = Serial.read();
Serial.println("right after char c");
Serial.write(c);
Serial.println("after write c");
Serial.println(c);
if (c < '0' || c > '9') {
Serial.println(F("\nInvalid digit"));
return;
name[BASE_NAME_SIZE + i] = c;
Serial.println("name base size:");
Serial.println(c);
Serial.println(&name[BASE_NAME_SIZE+2]);
if (!sd.exists(name)) {
Serial.println(F("File does not exist"));
return;
binFile.close();
strcpy(binName, name);
if (!binFile.open(binName, O_RDONLY)) {
Serial.println(F("open failed"));
return;
Serial.println(F("File opened"));
Essentially what is happening if I use the original code above is that it will not wait for the character input it just goes straight to the "Invalid digit".
I was able to modify the code to at the very least get it wait for the text entry but it does not seem to read the characters or be able to move forward with the rest of the function. From what I can tell the For loop will read each byte or character inputted and count up to 2 and I think stacks that number for processing?
Here is my modified code:
bool waitForNum = true;
while (waitForNum == true) {
yield();
Serial.write(c);
return;
Serial.println(c);
if ( i == 2) {
waitForNum = false;
Serial.println("This has executed");
return;
binFile.close();
return;
I'm sure I am missing something super basic any help would be appreciated. Thanks!
