Wake arduino by RTC do task and sleep
Hello
I am new to this. Need to wake up my arduino every 2 hours and should be awake for minimum 1 minute to do task and then it should go sleep.
I found some code on internet. can some one please guide me where i should make changes to wakeup arduino every 2 hours and slepp after 1 minute.
#include <Wire.h>
#include <RTClibExtended.h>
#include <LowPower.h>
#define wakePin 2    //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
#define ledPin 13    //use arduino on-board led for indicating sleep or wakeup status
RTC_DS3231 RTC;      //we are using the DS3231 RTC
byte AlarmFlag = 0;
byte ledStatus = 1;
void wakeUp()        // here the interrupt is handled after wakeup
  //Set pin D2 as INPUT for accepting the interrupt signal from DS3231
  pinMode(wakePin, INPUT);
  //switch-on the on-board led for 1 second for indicating that the sketch is ok and running
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  //Initialize communication with the clock
  Wire.begin();
  RTC.begin();
  RTC.adjust(DateTime(__DATE__, __TIME__));   //set RTC date and time to COMPILE time
  //clear any pending alarms
  RTC.armAlarm(1, false);
  RTC.clearAlarm(1);
  RTC.alarmInterrupt(1, false);
  RTC.armAlarm(2, false);
  RTC.clearAlarm(2);
  RTC.alarmInterrupt(2, false);
  //Set SQW pin to OFF (in my case it was set by default to 1Hz)
  //The output of the DS3231 INT pin is connected to this pin
  //It must be connected to arduino D2 pin for wake-up
  RTC.writeSqwPinMode(DS3231_OFF);
  //Set alarm1 every day at 18:33
  RTC.setAlarm(ALM1_MATCH_HOURS, 33, 18, 0);   //set your wake-up time here
  RTC.alarmInterrupt(1, true);
  //On first loop we enter the sleep mode
  if (AlarmFlag == 0) {
    attachInterrupt(0, wakeUp, LOW);                       //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
    digitalWrite(ledPin, LOW);                             //switch-off the led for indicating that we enter the sleep mode
    ledStatus = 0;                                         //set the led status accordingly
    LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);   //arduino enters sleep mode here
    detachInterrupt(0);                                    //execution resumes from here after wake-up
    //When exiting the sleep mode we clear the alarm
    RTC.clearAlarm(1);
    AlarmFlag++;
  //cycles the led to indicate that we are no more in sleep mode
  if (ledStatus == 0) {
    ledStatus = 1;
  else {
    ledStatus = 0;
See the examples and documentation on your RTC library, in detail the setAlarm() method.
