Wake up from sleep
Great!
I added this code before the arduino get to sleep to force the pins to be high, and it worked!
for (int i=2; i <= 5; i++){
      digitalWrite(i, HIGH);
      delay(10);
And I am setting those back to LOW when we are awake. So now everything is working and this is the best solution!!!!
Big thanks for all you help, very kind!
Joakim
jkrassman:
I just checked all pins and they are all LOW?
Are you using an older version of the keypad library? The current version sets the columns to inputs with pullup enabled after a scan (although not until you have done at least one scan). Try setting the column pins to inputs with pullup enabled, just before you set the rows to be outputs.
[EDIT: looks like you just found this solution yourself!]
Yes, so this came out to be a really good solution. No need for extra wiring or nada - just plugin the keypad to the board and hit run, and we have a lift of!
Big thanks again, I would never have figured this out!
Joakim
