Is it possible to wake up on a timer overflow interrupt? I'm making a clock and using timer 2's asynch capabilities to count from an external 32 khz crystal. Since it will be battery powered, I want to put the MCU to sleep as much as possible and only wake up to increment the second counter. Is it possible?
Sure. See chapter 9 of the data sheet, and http://www.nongnu.org/avr-libc/user-manual/group__avr__sleep.html.
A while ago I posted some example sleep code which uses the watch-dog timer to wake up (Breaking the .7 mA barrier? - #31 by tim7 - Microcontrollers - Arduino Forum). But the watch-dog isn't terribly accurate, so you'd probably want the "power-save" mode rather than the "power-down" mode. This mode leaves the timers running, and a Timer2 overflow or output-compare event can wake the CPU -- see the TIMSK2 register description in the datasheet.
