Wake up on serial
I have some serial device( bluetooth) connected to the RX pin of the device .
I am trying to wake it up on connection .
So I can put the device to sleep, and I know that it gets the Rx signal, but it won’t wake up .
I must say , it worked once, then stopped working, so i know the setup is good (=led/rx)
There is the code to sleep and wake :
#include <avr/sleep.h>
const byte interruptPin = 2;
void sleepSystem()
      //attach interrupt
       pinMode(interruptPin, INPUT_PULLUP); //INPUT DID NOT WORK
       EIFR = _BV(INTF1);
       attachInterrupt(interruptPin, wakeOnSerial, CHANGE); //RISING DID NOT WORK
     set_sleep_mode (SLEEP_MODE_PWR_DOWN);
     sleep_enable();
     sleep_cpu ();
void wakeOnSerial()
  detachInterrupt(interruptPin);
  digitalWrite(LED1,HIGH);     // LED IS CERTAINLY FUNCTIONAL
Any suggestion what wrong here ?
Thank you .
EDIT :
Have changed this line , now it works but the interrupt happens right when I attach it :
attachInterrupt(digitalPinToInterrupt(interruptPin), wakeOnSerial, FALLING); //RISING IS THE SAME
