Waking from ADC /AC interrupt
I want to wake the AirBoard< http://www.theairboard.cc/> which is Arduino compatible from a capacitive touch sensor. Be sure there is only one AD input, I have choosen the ADCTouch library.
Beacuse of this ADC convertor, I have choosen the sleep mode ADC. I did a very simple test, control the LED in using ADC sleep mode. But there are problems. When I am in the sleep mode, LED blinks with weak current, I don't know why it appeared this current? Anyone knows?
Or maybe I can use the Analogical Comparator Interrrupt?
#include <ADCTouch.h>
#include <avr/sleep.h>
#include <avr/power.h>
int ref;       //reference values to remove offset
const int LED1=12;
const int LED2=13;
const int adcPin=5;
// when ADC completed, take an interrupt
EMPTY_INTERRUPT (ADC_vect);
// in sleep mode (ADC)
void sleepNow (const byte port)
  cli();
  bitSet (DIDR0, ADC0D);  // disable digital buffer on A0
  bitSet (DIDR0, ADC1D);  // disable digital buffer on A1
  bitSet (DIDR0, ADC2D);  // disable digital buffer on A2
  bitSet (DIDR0, ADC3D);  // disable digital buffer on A3
  bitSet (DIDR0, ADC4D);  // disable digital buffer on A4
  ADCSRA =  bit (ADEN) | bit (ADIE) | bit (ADIF);   // turn ADC on, want interrupt on completion
  ADCSRA |= bit (ADPS0) | bit (ADPS1) | bit (ADPS2);   // prescaler of 128
  ADMUX = bit (REFS0)|bit (REFS1)| (port & 0x07);
  set_sleep_mode (SLEEP_MODE_ADC);
  noInterrupts ();
  // sleep during sample
  sleep_enable();
  ADCSRA |= bit (ADSC) | bit (ADIE);
  int value= ADCTouch.read(A5, 500);    //create reference values to
         //account for the capacitance of the pad
  value-=ref;
  if(value>15)  // value tested
    interrupts ();
    sleep_cpu ();
    sleep_disable ();
  while (bit_is_set (ADCSRA, ADSC))
  // awake again
  }  // end of sleep
  void setup ()
     pinMode(LED1, OUTPUT);
     digitalWrite(LED1, LOW);
     pinMode(LED2, OUTPUT);
     digitalWrite(LED2, LOW);
     ref = ADCTouch.read(A5, 500);    //create reference values to
         //account for the capacitance of the pin
    }  // end of setup
void loop () {
  digitalWrite(LED1, HIGH);
  digitalWrite(LED2, HIGH);
  delay(2000);
  sleepNow(adcPin);
You must have some active touch sensor, that detects a touch without polling for it in code. Else the sensor won't do anything, and cannot create an interrupt, while the controller sleeps.
My understanding of ADC noise canceler (SLEEP_MODE_ADC?) is for sleeping only during one ADC conversion, but I may be wrong with your board/controller.
