Walkie-talkie con NRF24L01 + LCD + 74HC595N
Buenas a todos. Soy nuevo y espero redactar bien el post y expresar bien mi problema.
Mi problema es que no consigo que funcione el LCD.
Os explico, tengo un par de Arduinos UNO conectados a unos módulos NRF24L01 a modo de Walkie-talkies y funcionan correctamente, aquí os pongo un esquema:
Este es el código que utilizo:
#include <RF24.h>
#include <SPI.h>
#include <RF24Audio.h>
#include "printf.h"
#include "userConfig.h"
RF24 radio(7,8);
RF24Audio rfAudio(radio,0);
int talkButton = 3;
printf_begin();
radio.begin();
radio.printDetails();
rfAudio.begin();
pinMode(talkButton, INPUT);
attachInterrupt(digitalPinToInterrupt(talkButton), talk, CHANGE);     //Interrupcción en modo de cambio (CHANGE)
rfAudio.receive();
void talk()
   if (digitalRead(talkButton)) rfAudio.transmit();
   else rfAudio.receive();
(Decir que el "userConfig.h" lo añado como fichero aparte para modificar algunas características del módulo NRF24L01):
//******* MANDATORY User Variables **************/
 // Maximum Range: Sample rate 16000, RF_SPEED RF24_250KBPS
 // Maximum Quality: Sample rate 44000, RF_SPEED RF24_2MBPS
#define SAMPLE_RATE 24000                     // The sample rate to use for transferring audio samples  Note: 44khz+ sample rate requires 8-bits per sample
#define RF_SPEED RF24_1MBPS                   // RF24_250KBPS will do 13-20khz+ sample rate, RF24_1MBPS up to 24-44khz+, RF24_2MBPS for higher. These are not limits, just a guide.
#define ANALOG_PIN A0                         // The pin that analog readings will be taken from (microphone pin)
/************ OverRides *************************/
//10-bit audio requires more bandwidth. A 20khz sample rate will need 25KB/S transfer rate, which is about max for 250kbps data rate.
//With a 32khz sample rate, the volume can be set to -1 to shift the sample down to 9-bit, which is the highest the timers can handle at 32khz
//#define tenBit                              // Enable 10-bit samples   Note: 44khz+ sample rate requires 8-bits per sample
//#define speakerPin 9						  // If using a non-standard board, override the timer1 pins
//#define speakerPin 10
#define ENABLE_LED                        	  // Indicator pin. Using pin 6 on Uno enables audio visualization. Pin 13 on Mega 2560 (TIMER0 COMPA) The pin# cannot be changed.
/***************** Optional/Advanced User Variables ******/
//#define MANUAL_BUTTON_HANDLING			  // Disables button handling via timer0. Allow users to customize button handling
//#define TX_PIN A1                             // Button pin to trigger recording & transmission
#define VOL_UP_PIN A2                         // Pin for external volume control
#define VOL_DN_PIN A3                         // Pin for external volume control
//#define REMOTE_TX_PIN A4                      // Pin for externally triggering remote recording
//#define REMOTE_RX_PIN 4                       // Pin for externally stopping remote recording (needs timeout enabled)
#define buffSize 32                           // The size of the memory buffer to use. Not really configurable.
//#define speakerTX                           // Whether to output to speaker while transmitting
//#define oversampling                        // Oversampling is recommended for low sample rates only. This only affects playback.
//#define RX_ONLY
//#define TX_ONLY // Not functional yet
/*********  Automated pin selections, override by defining above  ************/
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || (__AVR_ATmega32U4__) || (__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__) || (__AVR_ATmega128__) ||defined(__AVR_ATmega1281__)||defined(__AVR_ATmega2561__)
  #define rampMega
  #if !defined (speakerPin)	//Speaker pin selection for mega etc
    #define speakerPin 11                          //The pins to output audio on. (11,12 on Mega 2560)
  #endif
  #if !defined (speakerPin2)
    #define speakerPin2 12
  #endif
  #if defined (ENABLE_LED)
    #define ledPin 13
  #endif
#else  //Speaker selection for Uno,Nano, etc
  	#define speakerPin 9                          //The pins to output audio on. (9,10 on UNO,Nano)
  #endif
	#define speakerPin2 10
  #endif
    #define ledPin 6
  #endif
#endif
//********Radio Defines ****************************
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[14] = { 0xABCDABCD71LL, 0x544d52687CLL, 0x544d526832LL, 0x544d52683CLL,0x544d526846LL, 0x544d526850LL,0x544d52685ALL, 0x544d526820LL, 0x544d52686ELL, 0x544d52684BLL, 0x544d526841LL, 0x544d526855LL,0x544d52685FLL,0x544d526869LL};
Bien pues quiero añadirle una pantalla LCD pero al no tener pines suficientes la añado gracias al circuito integrado 74HC595N, utilizando sólo 3 pines del Arduino. Al principio los conecté a los pines digitales 2, 4 y 5, e introduciendo sólo el código de la LCD + 74HC595N funciona:
#include <Wire.h>
#include <LiquidCrystal_SR3W.h>
const int PIN_LCD_STROBE =  4; // Out: LCD IC4094 shift-register strobe LACH PIN  - STCP
const int PIN_LCD_DATA =  2;   // Out: LCD IC4094 shift-register data     DATA PIN  - DS
const int PIN_LCD_CLOCK =  5;  // Out: LCD IC4094 shift-register clock   CLOCK PIN - SHCP
LiquidCrystal_SR3W lcd(PIN_LCD_DATA, PIN_LCD_CLOCK, PIN_LCD_STROBE); // srdata / srclock / strobe
// Creat a set of new characters
byte armsUp[8] = {0b00100,0b01010,0b00100,0b10101,0b01110,0b00100,0b00100,0b01010};
byte armsDown[8] = {0b00100,0b01010,0b00100,0b00100,0b01110,0b10101,0b00100,0b01010};
void setup(){
  lcd.begin(16,2);               // initialize the lcd
  lcd.createChar (0, armsUp);    // load character to the LCD
  lcd.createChar (1, armsDown);    // load character to the LCD
  lcd.home ();                   // go home
  lcd.print("WALKIE-TALKIE");
void loop(){
  // Do a little animation
  for(int i = 0; i <= 15; i++) showHappyGuy(i);
  for(int i = 15; i >= 0; i--) showHappyGuy(i);
void showHappyGuy(int pos){
  lcd.setCursor ( pos, 1 ); // go to position
  lcd.print(char(random(0,2))); // show one of the two custom characters
  delay(550); // wait so it can be seen
  lcd.setCursor ( pos, 1 ); // go to position again
  lcd.print(" "); // delete character
Se ve correctamente, el problema viene al intentar unir los dos códigos, de esta manera (está puesto para verse Walkie-Talkie en la pantalla pero nada):
#include <RF24.h>
#include <SPI.h>
#include "printf.h"
#include <Wire.h>
const int PIN_LCD_STROBE =  15; // Out: LCD IC4094 shift-register strobe LACH PIN  - STCP    //LCD
const int PIN_LCD_DATA =  18;   // Out: LCD IC4094 shift-register data     DATA PIN  - DS    //LCD
const int PIN_LCD_CLOCK =  19;  // Out: LCD IC4094 shift-register clock   CLOCK PIN - SHCP   //LCD
LiquidCrystal_SR3W lcd(PIN_LCD_DATA, PIN_LCD_CLOCK, PIN_LCD_STROBE); // srdata / srclock / strobe   //LCD
RF24 radio(7,8);
int talkButton = 3;
printf_begin();
radio.begin();
rfAudio.begin();
rfAudio.receive();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
void talk()
Con este código los Arduinos siguen transmitiéndose información pero la pantalla LCD se queda en blanco, no sé por qué, no sé qué tipo de conflicto habrá en el código o si es por las librerías. Si me podéis echar una mano os lo agradeceré mucho. Perdón por tanto código, gracias de antemano y un saludo.
