walking robot program understanding
I learn programming by looking and trying to understanding other peoples programs.
I have a 4 legged walking robot which I 3d printed.
I don’t understand how the integer called “walk” in used this program I know its servo positions but I don’t see it being used in anywhere.
//#include <helper_3dmath.h>
  This is an example for our Adafruit 16-channel PWM & Servo driver
  Servo test - this will drive 16 servos, one after the other
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/815
  These displays use I2C to communicate, 2 pins are required to
  interface. For Arduino UNOs, thats SCL -> Analog 5, SDA -> Analog 4
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN  150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // this is the 'maximum' pulse length count (out of 4096)
int range = SERVOMAX - SERVOMIN;
// our servo # counter
uint8_t servonum = 0;
int pulselen = 0;
int pulseStep = 1;
byte pwmPin[16] =  {0, 0, 0, 0, 0, 0, 0, 0, 2, 3, 7, 6, 4, 5, 9, 10}; //{ 0, 1, 0, 0,  0, 0,  0, 0, 3, 2,  6, 7,  5, 4,  8, 9};
int middleShifts[16] = {0, 50, 0, 0,
                        -45, -45, -45, -45,
                        0, 0, 0, 0,
                        0, 0, 0, 0
float mg90s = 180 / 180.0, mg92b =  145 / 180.0;
float rangeRatios[] =  {mg92b, mg90s, mg92b, mg92b,
                        mg92b, mg92b, mg92b, mg92b,
int rotationDirections[16] = {1, -1, 1, 1,
                              1, -1, 1, -1,
                              1, -1, 1, -1,
                              -1, 1, -1, 1
int walk[][16] = {
  0,  0,  0,  0, -5,  5, -3,  3, 55, 64, 37, 38, 10, -1,  2, -8,
  0,  0,  0,  0, -5,  4, -3,  3, 58, 50, 33, 49, 10,  1,  2, -6,
  0,  0,  0,  0, -5,  2, -3,  1, 61, 33, 30, 58, 11,  9,  3,  0,
  0,  0,  0,  0, -5,  0, -3,  0, 64, 14, 26, 63, 13, 22,  4, 11,
  0,  0,  0,  0, -5, -3, -3, -2, 66,  7, 22, 63, 15, 28,  6, 18,
  0,  0,  0,  0, -5, -4, -3, -3, 67,  4, 19, 60, 17, 33,  9, 23,
  0,  0,  0,  0, -5, -5, -3, -3, 67,  8, 15, 58, 21, 32, 11, 22,
  0,  0,  0,  0, -5, -5, -3, -3, 67, 15, 11, 57, 24, 27, 15, 17,
  0,  0,  0,  0, -5, -5, -3, -3, 67, 22,  7, 55, 29, 22, 19, 13,
  0,  0,  0,  0, -5, -5, -3, -3, 66, 28,  3, 53, 34, 19, 23, 10,
  0,  0,  0,  0, -4, -5, -2, -3, 70, 34,  2, 50, 31, 16, 20,  7,
  0,  0,  0,  0, -1, -5, -1, -3, 76, 39,  4, 48, 24, 14, 14,  5,
  0,  0,  0,  0,  1, -5,  1, -3, 78, 44, 12, 45, 14, 12,  5,  4,
  0,  0,  0,  0,  4, -5,  2, -3, 76, 49, 23, 42,  4, 11, -4,  3,
  0,  0,  0,  0,  5, -5,  3, -3, 68, 53, 35, 38, -1, 10, -8,  2,
  0,  0,  0,  0,  5, -5,  3, -3, 55, 56, 46, 35,  0, 10, -7,  2,
  0,  0,  0,  0,  3, -5,  2, -3, 39, 60, 55, 32,  6, 11, -2,  3,
  0,  0,  0,  0,  1, -5,  0, -3, 20, 62, 62, 28, 17, 12,  7,  4,
  0,  0,  0,  0, -2, -5, -1, -3,  9, 65, 63, 24, 25, 14, 15,  5,
  0,  0,  0,  0, -4, -5, -2, -3,  4, 66, 61, 21, 32, 16, 22,  7,
  0,  0,  0,  0, -5, -5, -3, -3,  5, 67, 59, 17, 33, 19, 23, 10,
  0,  0,  0,  0, -5, -5, -3, -3, 13, 68, 57, 13, 28, 22, 19, 13,
  0,  0,  0,  0, -5, -5, -3, -3, 19, 67, 55,  9, 24, 27, 14, 17,
  0,  0,  0,  0, -5, -5, -3, -3, 26, 66, 53,  5, 20, 31, 11, 22,
  0,  0,  0,  0, -5, -4, -3, -3, 32, 67, 51,  2, 17, 33,  8, 23,
  0,  0,  0,  0, -5, -3, -3, -2, 37, 73, 49,  3, 14, 27,  6, 17,
  0,  0,  0,  0, -5,  0, -3,  0, 42, 77, 46,  6, 12, 21,  4, 11,
  0,  0,  0,  0, -5,  3, -3,  2, 47, 78, 43, 17, 11,  9,  3,  0,
  0,  0,  0,  0, -5,  4, -3,  3, 52, 73, 40, 29, 10,  1,  2, -6
void shutServos() {
  delay(250);
  for (byte i = 0; i < 16; i++) {
    pwm.setPWM(i, 0, 4096);
  Serial.begin(57600);
  Serial.println("16 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  yield();
  for (int servonum = 0; servonum < 16; servonum++) {
    //Serial.println(servonum);
    float duty = SERVOMIN + range / 2 ;
    pwm.setPWM(pwmPin[servonum], 0, 4096);//duty);
  delay(2000);
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= 60;   // 60 Hz
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000;
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
char num = '0';
int t = 0, tStep = 1;
  // Drive each servo one at a time
  if (Serial.available()) {
    num = Serial.read();
    shutServos();
  if (num == 'a')
      float duty =  (sin(2 * 3.14159 * t / 60.0)) * range / 2 * rotationDirections[servonum] / rangeRatios[servonum];
      pwm.setPWM(servonum, 0, SERVOMIN + range / 2 + duty);
  else {
    int servonum = num - '0';
    Serial.print(duty);
    Serial.print("\n");
  //pwm.setPWM(servonum, 0, 4096);
  t += tStep;
  t %= 60;
I don't see it being used in anywhere.
Neither do I
Where did you get the program ?
Cool looking walker!
I only see 8 servos and the code appears to reference 16. Why the difference.
Have you considered rolling your own code?
UKHeliBob:
Neither do I
from here https://www.petoi.com/ in there git hub
vinceherman:
the servo driver has 16 channels. Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface [PCA9685] : ID 815 : $14.95 : Adafruit Industries, Unique & fun DIY electronics and kits
I will "roll my own code" as soon as i figure how to !LOL
jdolecki:
Learning is fun! I googled "arduino PCA9685 sweep" and found many tutorials and videos to help.
Start with something simple then move to more complex.
Assuming that you are able to successfully tackle the details of coding for the PCA9685, what are your goals for the walker?
I expect that you can make it walk forward and backward with a few simple loops.
Looking at GitHub it looks like the sketch posted above is just one of many test programs and that various variables are used in different tests. The one posted does not use the walk array
