Here is the code:
// Libraries Declarations //
#include <Servo.h>
#include <SD.h>
// Initialising Map //
char UnknownMaze[22][22] =
char SolvedMaze[22][22] =
// Initalising and declaring varaibles //
int servoPin = 2;
Servo servo;
const int pingPin = 3;
unsigned int duration,inches;
int leftscan,centerscan,rightscan;
boolean scan = true;
int LEDPin = 53; // Status LED connected to digital pin 13
int row = 0;
int column = 0;
int columnrobot = 5;
int rowrobot = 20;
int uTurn = 0;
int Movement = 0;
int MinimumSafeDistance = 10;
char Direction;
// Unknown Maze Function //
void UnknownMap()
// Making an 2D array of the unknown Maze //
row = 0;
column = 0;
for(row = 0;row < 22;row++)
for(column = 0;column < 22;column++)
Serial.print(UnknownMaze[row][column]);
Serial.print(' ');
Serial1.write(UnknownMaze[row][column]);
Serial1.write(' ');
Serial2.write(UnknownMaze[row][column]);
Serial2.write(' ');
Serial.print("\n");
Serial1.write("\n");
Serial2.write("\n");
Serial.print("\n");
// Solved Maze Function //
void SolvedMap()
// Making an 2D array of the Solved Maze //
row = 0;
column = 0;
Serial.print(SolvedMaze[row][column]);
Serial.print(' ');
Serial1.write(SolvedMaze[row][column]);
Serial1.write(' ');
Serial2.write(SolvedMaze[row][column]);
Serial2.write(' ');
Serial.print("\n");
Serial.print("\n");
// Main Program where it's being performed once:
pinMode(LEDPin, OUTPUT); // Set the Pin to output
servo.attach(servoPin); // Set the Servo pin to output
Serial.begin(9600); // Setting the baud for serial monitor
Serial1.begin(9600); // Setting the baud for bluetooth
Serial2.begin(9600); // Setting the baud for OpenLog
delay(1000); // Wait a second for OpenLog to initiate
// Printing Unknown Maze map
Serial.print("Unknown MAZE");
Serial.print("\n");
Serial1.write("Unknown MAZE");
Serial2.write("Unknown MAZE");
UnknownMap(); // Call the unknown map Function
// Printing Solved Maze map
Serial.print("Solved Maze");
Serial.print("\n");
Serial1.write("Solved Maze");
Serial2.write("Solved Maze");
SolvedMaze[21][5] = 'S'; // Set the entrance of the robot
SolvedMap(); // Call the solved map Function
