Wanna make ESP32 client read; turn on LED from another ESP32(AP)
hi
The two ESP32s I have.
AP mode.
Client mode.
Number 1 communicates with number 2 when digital read(from no.1's PIN 21).
Number 2 will turn on the built-in LED when receiving the serial character ("1") from Number1.
What should I do for this code to work properly?
    This sketch sends a message to a AP ("""client mode (no.2)""")
#include <WiFi.h>
#include <WiFiMulti.h>
WiFiMulti WiFiMulti;
char val;
const int led = 2;
  delay(10);
  pinMode(led, OUTPUT);
  // We start by connecting to a WiFi network
  WiFiMulti.addAP("ESP32", "11111111");
  Serial.print("Waiting for WiFi... ");
  while (WiFiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  //    const uint16_t port = 80;
  //    const char * host = "192.168.1.1"; // ip or dns
  const char * host = "192.168.4.1"; // ip or dns
  Serial.print("Connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port)) {
    Serial.println("Connection failed.");
    Serial.println("Waiting 5 seconds before retrying...");
    delay(5000);
    return;
  while (client.connected()) {
    while (client.available()) {
      char c = client.read();
      if (c == '1') {
        digitalWrite(led, HIGH);// perform some action
      else {
        digitalWrite(led, LOW);// maybe perform some other action
      // This will send a request to the server
      //uncomment this line to send an arbitrary string to the server
      //client.print("Send this data to the server");
      //uncomment this line to send a basic document request to the server
      client.print("GET /index.html HTTP/1.1\n\n");
      int maxloops = 0;
      //wait for the server's reply to become available
      while (!client.available() && maxloops < 1000)
        maxloops++;
        delay(1); //delay 1 msec
      if (client.available() > 0)
        //read back one line from the server
        String line = client.readStringUntil('\r');
        Serial.println(line);
        Serial.println("client.available() timed out ");
      Serial.println("Closing connection.");
      client.stop();
      Serial.println("Waiting 5 seconds before restarting...");
      delay(5000);
and, below no.1 (AP mode)'s code.
you can find there control + F < if (currentSensorState == 1) >
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
const char *ssid = "ESP32";
const char *password = "11111111";
WiFiServer server(80);
#define SWITCH_PIN 21
int lastSensorState;
int currentSensorState;
int stateChangeCnt = 0;
  pinMode(SWITCH_PIN, INPUT);
  pinMode(2, OUTPUT);
  Serial.println("Configuring access point...");
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
  Serial.println("Server started");
  int switchValue = digitalRead(SWITCH_PIN);
  currentSensorState = digitalRead(SWITCH_PIN);
  WiFiClient client = server.available();
    if (client) {                             // if you get a client,
      Serial.println("New Client.");           // print a message out the serial port
      String currentLine = "";                // make a String to hold incoming data from the client
      while (client.connected()) {            // loop while the client's connected
        if (client.available()) {             // if there's bytes to read from the client,
          char c = client.read();             // read a byte, then
          Serial.write(c);                    // print it out the serial monitor
          if (c == '\n') {                    // if the byte is a newline character
            // if the current line is blank, you got two newline characters in a row.
            // that's the end of the client HTTP request, so send a response:
            if (currentLine.length() == 0) {
              // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
              // and a content-type so the client knows what's coming, then a blank line:
              client.println("Content-type:text/html");
              client.println();
              // the content of the HTTP response follows the header:
              client.print("Click <a href=\"/H\">here</a> to turn ON the LED.<br>");
              client.print("Click <a href=\"/L\">here</a> to turn OFF the LED.<br>");
              // The HTTP response ends with another blank line:
              client.println();
              // break out of the while loop:
            } else {    // if you got a newline, then clear currentLine:
              currentLine = "";
          } else if (c != '\r') {  // if you got anything else but a carriage return character,
            currentLine += c;      // add it to the end of the currentLine
            if (currentSensorState != lastSensorState) {
              if (currentSensorState == 1) // heat switch off
                client.println("switch1.");
                client.write("1");
                digitalWrite(2, LOW);
                digitalWrite(2, HIGH);
              if (lastSensorState == 1) //switch on
                client.println("switch2.");
              lastSensorState = currentSensorState;
              stateChangeCnt++;
            else {
            // close the connection:
            client.stop();
            // Check to see if the client request was "GET /H" or "GET /L":
thanks!
Despite the title of the topic neither sketch includes a Serial.read()
Do you mean client.read() ?
yeah, I mean client.read() . thanks.
    if  (client.print(String("switch1."))) {
    else {
