Currently it shows up as an Arduino Micro under the Ports tab, I want it to show as a HID Keyboard device under Keyboards.
Load up the example sketch for that from the IDE menus.
Hi @lcarduinotech. If you upload a sketch that uses the "Keyboard" library to the Leonardo, it will produce a HID keyboard device, which you will see in Windows Device Manager.
In addition to the HID device, the board also produces a USB CDC serial port. So the fact that you see a serial port device for the board in Device Manager does not mean that it is not producing an HID device.
Ahh ok I see, yes I notice that now.
Is there a way to remove the USB CDC serial port so that nothing shows up in device manager that says Arduino. It's for a product I'm selling and I think it would look a little more professional.
I recommend you verify that any code you incorporate is either your own work or explicitly licensed for commercial use. Take the time to review all license agreements associated with any components or libraries you acquire, this will help you avoid legal problems down the road.
