Want to ask, why the serial monitor is not showing the reading/results for esp32 board
When the serial monitor is open, it shown :
Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:1324 ho 0 tail 12 room 4 load:0x40078000,len:13480 ho 0 tail 12 room 4 load:0x40080400,len:3604 entry 0x400805f0
Welcome to the forum
Do you have a question ?
What do you think should be printing on the Serial monitor ?
Please post a sketch that illustrates any problem that you have
This my code :
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <LiquidCrystal.h> // includes the LiquidCrystal Library
#include <DHT.h>
#include <Adafruit_Sensor.h>
#define BLYNK_PRINT Serial
#define WIFI_SSID "-"
#define WIFI_PASSWORD "-"
// You get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char host[] = "KGK6boy4kCS9ZTW915FV5YmVT9hV12uN";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "xxxxxx";
char pass[] = "xxxxx";
#define DHTPIN 4
#define DHTTYPE DHT11
LiquidCrystal lcd(1, 2, 4, 5, 6, 7); // Creates an LCD object. Parameters: (rs, enable, d4, d5, d6, d7)
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
char pumpon [] = "ON";
char pumponmanual [] = "ON MANUAL";
char pumpoff [] = "OFF";
int solenoidPin = 4; //This is the output pin on the Arduino we are using
int temperature;
int humidity;
void pushswitch_button_Sensor()
Blynk.run();
float humidity = dht.readHumidity();
float temperature = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
Blynk.virtualWrite(V5, temperature);
Blynk.virtualWrite(V6, humidity);
if (temperature >= 24 && humidity <= 60) {
Serial.println(" - Surrounding is HOT");
digitalWrite(solenoidPin, HIGH); //Switch Solenoid ON
Blynk.virtualWrite(V10, pumpon);
else if (temperature <= 24 && humidity >= 60) {
Serial.println(" - Surrounding is COLD");
digitalWrite(solenoidPin, LOW); //Switch Solenoid OFF
Blynk.virtualWrite(V10, pumpoff);
lcd.begin(16, 2); // Initializes the interface to the LCD screen, and specifies the dimensions (width and height) of the display
pinMode(solenoidPin, OUTPUT); //Sets the pin as an output
// Debug console
Serial.println("DHT22 Output!");
dht.begin();
Serial.print("Connecting to ");
Serial.println(ssid);
timer.setInterval(1000L, pushswitch_button_Sensor);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Blynk.begin(host, ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
BLYNK_WRITE (V8)
int pinValue = param.asInt ();
if (pinValue == 1) {
Serial.println ( " SOLENOID ON FROM MANUAL CONTROL" );
Blynk.run();
Blynk.virtualWrite (V10, pumponmanual);
int pinValue = 0;
Blynk.syncVirtual (V8);
else {
pushswitch_button_Sensor();
void displayData_LCD() {
lcd.setCursor(0, 0); // Sets the location at which subsequent text written to the LCD will be displayed
lcd.print("Temp.: "); // Prints string "Temp." on the LCD
lcd.print(temperature); // Prints the temperature value from the sensor
lcd.print(" C");
Serial.print("temperature = ");
Serial.print(temperature);
Serial.print("C ");
lcd.setCursor(0, 1);
lcd.print("Humi.: ");
lcd.print(humidity);
lcd.print(" %");
Serial.print("Current humidity = ");
Serial.print(humidity);
Serial.print("% ");
delay (1000);
void sendData_MYSQL() {
Serial.print("connecting to ");
Serial.println(host);
if (isnan(humidity) || isnan(temperature)) {
Serial.println("Failed to read from DHT sensor!");
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 5555;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
// This will send the request to the server
client.print(String("GET http://your_hostname/iot_project/connect.php?") +
("&temperature=") + temperature +
("&humidity=") + humidity +
" HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 1000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println("closing connection");
Blynk.run();
timer.run();
displayData_LCD();
sendData_MYSQL();
But the reading of DHT is not show in serial monitor......
Thank you for posting the sketch but please edit the post and add code tags to it
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
When you posted your code without code tags did you receive a warning message ?
These need to match...
