Want to changer the IP from the Yún WiFi
I am trying to change the IP as described here http://arduino.cc/en/Guide/ArduinoYun#toc13 but with no luck.
My laptop runs on Windows8.
The Yún is connected true the USB cable.
If i try to connet to the Yún using my laptop, the device is shown in the available connections list, i get a warning that there are only limited services available for that connection. It has the IP address 192.168.240.222.
But if i do a Ping to the Yún on 192.168.240.1 i get no reaction.
Is this normal or am i doing something wrong or is there a problem with my configuration?
Harry
Connect ethernet cable between wifi router and yun will make your life easy.
