Hello everyone ...
I hope that you are good and doing well.
I want to display the values from the OLED wirelessly and I need you to make some changes in my code; I also have two Arduinos and currently I am using this this code to see the values on an OLED display with wire.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
B00000001, B11000000,
B00000011, B11100000,
B11110011, B11100000,
B11111110, B11111000,
B01111110, B11111111,
B00110011, B10011111,
B00011111, B11111100,
B00001101, B01110000,
B00011011, B10100000,
B00111111, B11100000,
B00111111, B11110000,
B01111100, B11110000,
B01110000, B01110000,
B00000000, B00110000 };
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
//BATTERY READINGS VARIABLES
const int Battery = A0;
float Voltage = 0.0; //input battery voltage
float Voltage1 = 0.0; //output voltage for analog pin A0
float R1 = 74000; // R1 =47k ohms and 27k ohms resistors
float R2 = 10000; // R2 =10k ohms resistor
int readValue = 0;
long previousMillis_battery = 0;
byte Bat_start_timer = 0;
int battery_wait;
unsigned long currentMillis = 0; // VALID FOR ALL FUNCTIONS(COUNTER)
//BATTERY FUNCTION
void battery()
readValue = analogRead(Battery);
Voltage1 = readValue * (5.0 / 1023.0);
Voltage = Voltage1 / (R2/(R1+R2));
if(Bat_start_timer == 0) battery_wait = 2000;
if(currentMillis - previousMillis_battery > battery_wait) {
// Serial.println("Battery Voltages,"); Serial.print(Voltage); Serial.print(",V,");
previousMillis_battery = currentMillis;
battery_wait = 2000; Bat_start_timer = 1; }
} // battery FUNCTION END
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
display.display();
delay(2000);
display.clearDisplay(); // Clear the buffer.
// currentMillis=millis(); // if you want to see the voltages on serial monitor then open this one
// battery();
display.setTextSize(1.5);
display.setTextColor(WHITE);
display.setCursor(1,4);
display.println("ABC System Started");
battery();
display.setTextSize(2);
display.setCursor(28,18);
display.print (Voltage);
display.println("V");
display.display();
delay(2000);
I am using an external radio module for my transmitter and receiver using a serial port TX0, and RX0 so no need of library
Thank you soo much
