Want to fade ledPin2 after ledPin1 ends
Hello,
I am attempting to write a welding torch simulator sketch for model railroading… I have the White (ledPin1) doing what I want but I’m stuck when I try to get my “glow” (ledPin2)to start out full on and fade down to 0 when ledPin1 finishes flashing… I want it to appear as if the ledPin2 is the metal glowing and cooling after the torch stops.
int ledPin =  2;    // LED connected to digital pin 2.. Torch
int ledPin2 = 3;  // LED connected to digital Pin 3.. Glow
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
void setup()   {
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  int i, count;  count = random(10, 190);
  for (i = 0; i < count; i++) {
    digitalWrite(ledPin, HIGH);   // set the ledPin 1 LED on
    delay(random(20));
    //digitalWrite(ledPin2, HIGH);
    digitalWrite(ledPin, LOW);    // set the LED off
    delay(random(55));
    analogWrite(ledPin2, brightness); // Set the ledPin2 LED to full on
    brightness = brightness + fadeAmount;
   // reverse the direction of the fading at the ends of the fade:
   if (brightness == 5 || brightness == 255) {
     fadeAmount = -fadeAmount ;
   // wait for 30 milliseconds to see the dimming effect
   delay(30);
    digitalWrite(ledPin2, HIGH);   // set the LED on
    delay(random(520, 2000));
    digitalWrite(ledPin2, LOW);    // set the LED off
    delay(random(1000, 5000));
Welder_Simulator_with_glow_With_Dimming.ino (1022 Bytes)
Perhaps because you have no dimming code? Just use a similar method to what you used to randomly dim/bright the torch, but change the random function to a decreasing ramp. Use analogWrite().
Ok..
Another hint please...
Where in the code should I insert it? After the digitalWrite(ledPin, LOW)?
int ledPin =  2;    // LED for "welders Torch"
int ledPin1 = 3;    // LED for "Hot Metal"
int i = 0;  // set i to 0
void setup()   {
  pinMode(ledPin, OUTPUT);  //sets pin to OUTPUT
  pinMode(ledPin1, OUTPUT); //sets pin to OUTPUT
// Set up welders torch strobing
    digitalWrite(ledPin, HIGH);   // set the LED on
    delay(random(20));
    delay(random(55));
    // Set up Hot Metal Effect (fade)
    int i, count; count = random(10, 255);
    for (i = 0; i < count; i--) {
      analogWrite(ledPin1, i); {
        brightness = brightness - fadeAmount;
        if (brightness == 255 || brightness == 120)
          fadeAmount = -fadeAmount;
        delay(10);
one of these days I'll post correctly :frowning:
I added my fading code and it works as written.. BUT (you knew that was coming) now I get the torch doing its strobing, then it stops as written, the fading starts and goes to low and it keeps repeating the fade down..
What am I missing here????
I noticed if I let the sketch run for a while (5-10 minutes) the torch part of the loop will run again for one loop then the fade keeps looping for another 5 or so minutes…
I have searched for my mistake but my limited knowledge is not finding it…
Please tell me where I messed up… I’m so close !!
I GOT IT… at least it seems to work…
Any suggestions as to cleaning it up or streamlining it?
Thanks for the guidance on the fade down…
int j = 0;  // set i to 0
void setup()   {
    delay(random(20));
    delay(random(55));
    int j = 0;
        for (j = 255; j >= 0; j-=5) {
          analogWrite(ledPin1, j);
          if (brightness == 0 || brightness == 255)
            fadeAmount = -150;//fadeAmount;
          delay(20);
        analogWrite(ledPin1, LOW);
        delay(random(1000, 5550));
