I wish to implement a counter whenever a button is press, if the button is pressed, the counter will start if the sensor is detecting something, and if the button is not pressed, the counter will then restart to 0. but somehow, in my coding the counter will count regardless if the button is pressed or not. I hope you can guide me on solving this problem
the following is my code
int val = 0;
int counter = 0;
int currentState = 0;
int previousState = 0;
int sensorVal = 2;
const int buttonPin = 4 ;
int buttonState = 0;
pinMode(sensorVal,INPUT_PULLUP);
pinMode(buttonPin , INPUT);
void loop(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
sensorVal = digitalRead(2);
val = digitalRead(2); // read input value
if (val == HIGH)
currentState = 1;
currentState = 0;
if(currentState != previousState)
if(currentState == 1)
counter = counter + 1;
Serial.println(counter);
previousState = currentState;
delay(250);
else if (buttonState == LOW)
previousState = 0;
currentState = 0;
counter = 0;
you need to check for when it changes from LOW to HIGH. Something like this
prevButtonState = buttonState;
if (buttonState == HIGH and prevButtonState == LOW) {
// now you can increment the count if appropritate
Note that best practice is to wire a switch so it connects the button pin to GND when pressed. Then use pinMode(buttonPin, INPUT_PULLUP); and when the button is pressed the Arduino will see a LOW. If you want the button press to produce a HIGH then you should use an external pull-down resistor to prevent the pin from floating.
hey Robin2, I done what you did and it works perfectly but now I wanted to do is if you press the switch/button once, it will become toggle and during that time the if the sensor detects anything the counter will go up, but in my coding right now, after I press the switch the 2nd time, only then the counter will go up. is there anyway to help fix this. oh I am using boolean to make the switch act as a toggle.
ABSYR:
I find that hard to figure out.
I think your code is confusing the input from the sensor with the input from the button. In your code it seems that the currentState is changed depending on the IR value. But the text I've quoted seems to suggest that the state should change with the button press.
I suspect if you give more meaningful names to your variables things would become clearer. For example look at these two lines
int val = 2; //ir sensor
I suggest you do it like this
byte sensorPin = 2;
byte sensorState;
sensorState = digitalRead(sensorPin);
Even better than sensorState would be a name that relates to the purpose of the sensor - for example objectDetected
And the name "currentState" does not convey any sense of what it is keeping track of - is it a setting determined by the user or by the input from the sensor.
