This program works but I want to improve it. Two players press down and hold down a pb. A red led flashes 7 times and becomes solid. To first player to release the pb once the led becomes solid wins. To show which pb one a green led will flash beside the winners pb. The green led will flash for 5 sec and stop. Then a new game can start. One thing I want to improve is the creation of a "led light show" to celebrate the winner. Any other improvement I can do? By the way the help from this forum is great, and a special thank you to Larry!
int redled = 8; //pin 8 is the red led
int greenled1 = 4; // pin 4 is the green led 1
int pushbutton1 = 3; //pin 3 is the pushbutton 1
int greenled2 = 11; // pin 11 is the green led 2
int pushbutton2 = 10; // pin 10 is the pushbutton 2
void setup () {
pinMode (3,INPUT); //pin 3 is setup as an input
pinMode (4,OUTPUT); // pin 4 is setup as an output
pinMode (8,OUTPUT); // pin 8 is setup as an output
pinMode (10,INPUT); // pin 10 is setup as an imput
pinMode (11,OUTPUT); // pin 11 is setup as an output
void loop () {
digitalWrite(redled,HIGH); // the red led will be turn on and solid to start the game
digitalWrite(greenled1,LOW); // the green led 1 will be off
digitalWrite(greenled2,LOW); // the green led 2 will be off
if(digitalRead(10) && digitalRead(3) == HIGH){ //if both push buttons are pressed and held down
delay(30);
if(digitalRead(10) == HIGH && digitalRead(3) == HIGH){ //rechecks if buttons are pressed
delay(30);
for(int i=1;i<=7;i++){ // the red led will flash 7 times at a 2Hz frequency
digitalWrite(redled, HIGH);
delay(250);
digitalWrite(redled, LOW);
delay(250);
check(); // this is to check if someone let go of the button before the 7th flash.
while(digitalRead(10) && digitalRead(3) == HIGH){ //if both buttons are still press after the 7th flash the red led will become solid
if(digitalRead(10) == HIGH && digitalRead(3) == LOW){ // if pb2 release first as soon as redled comes solid then he wins.
digitalWrite(greenled1,HIGH); // this light show is to indicate the winner using the led next to pb2
for(int i=1;i<=10;i++){
digitalWrite(greenled1, HIGH); // I HAVE TO MAKE A "LIGHT SHOW" THAT LAST 5 SECONDS, ANY RECOMMENDATION TO MAKE THIS NICER?
delay(250);
digitalWrite(greenled1, LOW);
delay(250);
loop();
else if(digitalRead(10) == LOW && digitalRead(3) == HIGH){ //if pb1 release first as soon as redled comes solid then he wins
digitalWrite(greenled2,HIGH); //this led is to indicate the winner using the led next to pb1
for(int i=1;i<=10;i++){ // I HAVE TO MAKE A "LIGHT SHOW" THAT LAST 5 SECONDS, ANY RECOMMENDATION TO MAKE THIS NICER?
digitalWrite(greenled2, HIGH);
delay(250);
digitalWrite(greenled2, LOW);
delay(250);
loop();
void check(){
if(digitalRead(3) == HIGH && digitalRead(10) == LOW){ // if player 2 release too early then player 1 wins and is winner "light show" will start
for(int i=1;i<=10;i++){ // the green led will blink 10 times for a total of 5 seconds
delay(250);
delay(250);
else if(digitalRead(3) == LOW && digitalRead(10) == HIGH){ //if player 1 release too early then player 2 wins and his winner "light show" will start
for(int i=1;i<=10;i++){ // the green led 2 will blink 10 times for a total of 5 seconds, then the next game can start
delay(250);
delay(250);
loop();
