Want to make json call all the time.
Now get one json once. I want to pull values all the time.
Code :
#include <ArduinoJson.h>
#include <Ethernet.h>
#include <SPI.h>
#define RBUFFSIZE 600
boolean startCapture;
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
byte ip[] = { 192,168,1,56 };
byte server[] = { 192,168,1,38 };
char responseBuffer[RBUFFSIZE];
int rbindex = 0;
char c;
EthernetClient client;
Ethernet.begin(mac, ip);
Serial.println("connecting...");
int res = client.connect(server, 80);
if (res) {
Serial.println("connected");
client.println("GET /project/send_data.php");
client.println();
Serial.println("connection failed");
recive();
void recive(){
if(client.connected()){
c = client.read();
if(c == '{') {
startCapture=true;
const size_t bufferSize = JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(5) + JSON_OBJECT_SIZE(8) + 370;
DynamicJsonBuffer jsonBuffer(bufferSize);
if(startCapture && rbindex < RBUFFSIZE) {
responseBuffer[rbindex] = c;
rbindex++;
if (!client.connected()) {
Serial.println("Received bytes");
//Serial.print(strlen(responseBuffer));
Serial.println(responseBuffer);
StaticJsonBuffer<500> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(responseBuffer);
Serial.println((char*)root["a1"]);
Serial.println((char*)root["a20"]);
delay(2000);
Serial.println(rbindex);
jsonBuffer.clear();
The UNO has 2kB RAM, your sketch is requesting much more. You either forgot to mention that you're using another Arduino model or you got the source of your problem (although you didn't specify what your actual problem is).
pylon:
screenshot has Uno in bottom right corner
