want to use a CT to check for blown bulb
4 bulbs that are being used for a heater (these may be ceramic so they will admit no light)
to test that the bulb heater is working I want to monitor the amps as a simple pass or fail
so lets say that the bulb/heater is 40watt @110v so 0.36 amps
I just want to code something simple like
if output is on ct should read >0.25amps
now the trouble is I can find very little info on this ct
http://www.lctech-inc.com/Hardware/Detail.aspx?id=b7cc0993-f3c6-45ca-9614-9254d336114a
its a basic ct with a burden resistor that has 201 written on it
the web site says that a onboard sampling resistor has been added but they don't say what ohms that is. Is there such a thing as a 201 ohm resistor?
The next problem I presume will be that the ct will try to output ac in relationship to the primary winding.
I have looked at
http://openenergymonitor.org/emon/buildingblocks/ct-sensors-introduction
which gives a good information. I was just wondering if you guys have any advice as im only looking for a simple amp proven rather than monitoring setup. Im not sure if something as simple as a diode bridge and a capacitor could give me a basic stable dc voltage?
A resistor marked 201 is a 200 ohm resistor. (20*10^1) - same as the color code /ok
Everything you need to know is on that page.
transfer ratio is 1mA/A
5A = 5 mA out from the two little pins on the CT.
What more could you possibly need to know ?
How much electronics experience do you have ?
Maybe this would help.
or this
Possibly adding an RC LPF on the output of the rectifier would yield a readable analog voltage.
I would suggest a 4.7k ohm resistor with a 1 uF to 4.7 uF cap.
thanks for the help guys. I did O-level electronics in school over 25 years ago so reading and understanding a basic circuit is not a huge deal. The big difference is that electronics has advanced over the last 25 years and I have not kept up with the changes. I do not own a scope so im going to play with the ct on the bench and go from there. I have some industrial ct's 4-20ma so theres always plan B
You [EDIT] need a block diagram first . Then you can fill in the blocks.
DrAzzy:
yep that makes way more sense now.
