Hello all.
I would like to ask for help for my sketch.
There are two push buttons and two LEDs,
the intention is that if button 1 is pressed, LED 1 will flash ten times for three seconds.
The same for button 2 and LED 2.
When the buttons are not touched, the two LEDs fade alternately.
The sketch does work, problem is that when button 1 is pressed and LED 1 flashes,
button 2 and LED 2 do not react in the meantime due to the delays.
I would like to replace all delays in millis () then that problem should be fixed.
Below the code, thank you very much!
int value1, value2 ;
int S1 = 2; // switch P1
int S2 = 3; // switch P2
int L1 = 10; // led P1
int L2 = 11; // led P2
long time=0;
int periode = 8000;
int displace = 4000;
// initialize the digital pins.
// assume switches will wire from ground to input pins
pinMode(S1, INPUT_PULLUP);
pinMode(S2, INPUT_PULLUP);
pinMode(L1, OUTPUT);
pinMode(L2, OUTPUT);
if (!digitalRead(S1))
digitalWrite(L1,LOW);
digitalWrite(L2,LOW);
digitalWrite(L1,HIGH);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(1500);
delay(200);
if (!digitalRead(S2))
digitalWrite(L2,HIGH);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
delay(1500);
delay(200);
else {
time = millis();
value1 = 128+127*cos(2*PI/periode*time);
value2 = 128+127*cos(2*PI/periode*(displace+time));
analogWrite(L1, value2); // sets the value (range from 0 to 255)
analogWrite(L2, value1); // sets the value (range from 0 to 255)
