Want to use wired switches with Openhab
I trying to used wired light switches instead of the smart wireless ones mainly for security and high availabilty i.e when the wifi router or the zigbee/z-wave hubs goes down.
I tried searching on the internet for a commercial readymade modern stylish press button 5V switches but I couldnt find any.
I tried using 3 way light switch to control light side by side with the arduino uno connected to mqtt and openhab.
It is working fine, but the problem is that when I use the physical switch, I cannot update the mqtt topic with the state.
I searched around and I found that I can use the Analog pins in the arduino to measure if there is current going to the bulb from the relay!
Now I am stuck even to find this switch ready or to find an easier way of using the normal switches.
Any ideas!??
This will not be practical for many reasons, first because I cannot have that much analog slots to connect to all my light bulbs on the board. Second, it will be overcomplicated while wiring.
I tried to find another solution
Hmmm. Can you energize an opto isolator from the light circuit? Then you can read the digital state on the low voltage side.
