Wanted someone to do a little bit of code ££££
need someone to do some coding help and im willing to pay.
Ive been trying to get this done myself to limited success with the code below displays a 3 min countdown but for some reason I cant get it to start at 3.00 mins- it always starts at 3.09
//Using 2 7-segment displays with the 74HC595 shift registers
//CC by-sa-nc 3.0
//http://tronixstuff.wordpress.com
int minutesTens = 0; // count the minutes tens
int minutesUnits = 3; // count the minutes units
int secondsTens = 0; // count the seconds tens
int secondsUnits = 0; // count the seconds units
// Pin connected to ST_CP (pin 12) of 74HC595
int latchPin = 3;
// Pin connected to SH_CP (pin 11 of 74HC595
int clockPin = 10;
// Pin connected to DS (pin 14) of 74HC595
int dataPin = 12;
// Initialise a two Dimensional integer array with
// the values for 0 - 9 on the Seven Segment LED Display
// and 0-9 with the decimal point!
static byte seven_seg_digits[2][10]= {
0x7e, // 0
0x0c, // 1
0xb6, // 2
0x9e, // 3
0xcc, // 4
0xda, // 5
0xfa, // 6
0x0e, // 7
0xfe, // 8
0xce // 9
0x7e, // 0
0x0c, // 1
0xb6, // 2
0x9e, // 3
0xcc, // 4
0xda, // 5
0xfa, // 6
0x0e, // 7
0xfe, // 8
0xce // 9
without decimal point
{ 1,0,1,1,1,1,0,1 }, // = 189 in decimal
{ 1,0,0,0,0,1,0,0 }, // = 132 in decimal
{ 0,0,1,0,1,1,1,1 }, // = 47 in decimal
{ 1,0,0,0,1,1,1,1 }, // = 143 in decimal
{ 1,0,0,1,0,1,1,0 }, // = 150 in decimal
{ 1,0,0,1,1,0,1,1 }, // = 155 in decimal
{ 1,0,1,1,1,0,1,1 }, // = 187 in decimal
{ 1,0,0,0,1,1,0,0 }, // = 140 in decimal
{ 1,0,1,1,1,1,1,1 }, // = 191 in decimal
{ 1,0,0,1,1,1,1,0 }, // = 158 in decimal
with decimal point
{ 1,1,1,1,1,1,0,1 }, // = 253 in decimal
{ 1,1,0,0,0,1,0,0 }, // = 196 in decimal
{ 0,1,1,0,1,1,1,1 }, // = 111 in decimal
{ 1,1,0,0,1,1,1,1 }, // = 207 in decimal
{ 1,1,0,1,0,1,1,0 }, // = 214 in decimal
{ 1,1,0,1,1,0,1,1 }, // = 219 in decimal
{ 1,1,1,1,1,0,1,1 }, // = 251 in decimal
{ 1,1,0,0,1,1,0,0 }, // = 204 in decimal
{ 1,1,1,1,1,1,1,1 }, // = 255 in decimal
{ 1,1,0,1,1,1,1,0 }, // = 158 in decimal
// Just for further reference here are the
// separate segment connections
pin 2 = C
pin 3 = DOT
pin 4 = E
pin 5 = F
pin 6 = A
pin 7 = B
pin 8 = G
pin 9 = D
// set the arduino pins to output so you
// can control the shift register(s)
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
//Turn on the serial Monitor - useful for debugging!
//take the latch pin of the shift register(s) low
digitalWrite(latchPin, HIGH);
shiftOut(dataPin, clockPin, MSBFIRST, 0); // clears the 4th or secondUnits display
shiftOut(dataPin, clockPin, MSBFIRST, 0); // clears the 3rd or secondTens display
shiftOut(dataPin, clockPin, MSBFIRST, 0); // clears the 2nd or minutesUnits display
shiftOut(dataPin, clockPin, MSBFIRST, 0); // clears the 1st or minutesTens display
//take the latch pin of the shift register(s) high
digitalWrite(latchPin, LOW);
void timerCountDown(){
for (secondsUnits = 9; secondsUnits >= 0; secondsUnits--){
// take the latch pin of the shift register low
// Update the displays with the respective values
shiftOut(dataPin, clockPin, MSBFIRST, seven_seg_digits[0][secondsUnits]);
shiftOut(dataPin, clockPin, MSBFIRST, seven_seg_digits[0][secondsTens]);
shiftOut(dataPin, clockPin, MSBFIRST, seven_seg_digits[1][minutesUnits]);
shiftOut(dataPin, clockPin, MSBFIRST, seven_seg_digits[0][minutesTens]);
// take the latch pin high so the LEDs will light up:
// pause for a second before next value:
// for debugging send the count to the serial monitor
Serial.print("Timer Count = ");
Serial.print(minutesTens);
Serial.print(minutesUnits);
Serial.print(":");
Serial.print(secondsTens);
Serial.println(secondsUnits);
// check if the Seconds count is at 10
// if it is decrement the Seconds Tens count
// and reset the Minutes unit count to zero
if (minutesTens == 6 && minutesUnits == 0 && secondsTens == 0 && secondsUnits == 0){
Serial.println("you are here!");
minutesTens = 5;
minutesUnits = 9;
secondsTens = 6;
secondsUnits = 0;
if (minutesTens == 0 && minutesUnits == 0 && secondsTens == 0 && secondsUnits == 0){
minutesTens = 5;
minutesUnits = 9;
secondsTens = 6;
secondsUnits = 0;
if (minutesUnits == 0 && secondsTens == 0 && secondsUnits == 0){
minutesTens--;
minutesUnits = 9;
if (secondsTens == 0 && secondsUnits == 0){
minutesUnits--;
secondsTens = 6;
if (secondsUnits == 0){
secondsTens--;
secondsUnits = 0;
// call the function timerCountDown!
timerCountDown();
Im looking to get a countdown timer that will count down in Minutes to zero, outputting to a 4 LED 7 segment Sure DE-DP004 LED display (74hc595 shift register)
I want to be able to control the timer count down to stop and start it remotely and also want to be able to ( again via IR remote) choose 3 different start durations ( 10min , 3 min and 1 min)
Any offers?
Dude … don't do this.
Keep a value in seconds, starting from 180. Use the division and modulus operators to pull out the digits.
for(int seconds = 180; seconds >= 0; seconds--) {
  int minTens = (seconds / 600) % 6;
  int minOnes= (seconds / 60) % 10;
  int secTens = (seconds / 10) % 6;
  int minOnes= (seconds / 1) % 10;
  // rest of your code to stuff the correct digits out to your display goes here
Keep in mind that the arduino resonator is not as accurate as a crystal - one second isn't necessarily exactly 1000 ms.
You start with secondsUnits at 9, so no wonder you start at 3:09
