Wanting to pay for combining 2 arduino codes into 1
I've been trying to do it myself but am failing miserably, so I'm willing to pay for some one to code it for me.
I'm doing a Prop Cyberdeck project (Cyberdeck: fictional portable computer linked to VR or 3D glasses) that is themed around the movie Alien.
I bought and got running with the test code, an Adafruit DHT22 humidity and temperature sensor (DHT22 temperature-humidity sensor + extras : ID 385 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits) running on an Arduino Uno and reporting values back through the serial monitor:
HTx0°C
Humidity: 52.70%
Temperature: 22.70°C
Humidity: 52.80%
Humidity: 53.00%
90%
Temperature: 22.80°C
Humidity: 52.70%
Humidity: 52.80%
Humidity: 53.00%
DHTxx Unified Sensor Example
Temperature Sensor
Sensor Type: DHT22
Driver Ver:  1
Unique ID:   -1
Max Value:   125.00°C
Min Value:   -40.00°C
Resolution:  0.10°C
Humidity Sensor
Sensor Type: DHT22
Driver Ver:  1
Unique ID:   -1
Max Value:   100.00%
Min Value:   0.00%
Resolution:  0.10%
Humidity: 53.00%
Humidity: 52.90%
Humidity: 52.70%
Humidity: 52.70%
What I actually want is for the results of Temperature and Humidity to be displayed on 2x 4-Digit 7segment LCD displays which are connected to the Arduino with 4 wires: 5V, GND, CLOCK and D0. The library in use is the TM1637 by Avishay Orpaz.
Here is the code for the DHT22 sensor:
// DHT Temperature & Humidity Sensor
// Unified Sensor Library Example
// Written by Tony DiCola for Adafruit Industries
// Released under an MIT license.
// REQUIRES the following Arduino libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 7     // Digital pin connected to the DHT sensor
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
// Uncomment the type of sensor in use:
//#define DHTTYPE    DHT11     // DHT 11
#define DHTTYPE    DHT22     // DHT 22 (AM2302)
//#define DHTTYPE    DHT21     // DHT 21 (AM2301)
// See guide for details on sensor wiring and usage:
//   https://learn.adafruit.com/dht/overview
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
  // Initialize device.
  dht.begin();
  Serial.println(F("DHTxx Unified Sensor Example"));
  // Print temperature sensor details.
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  Serial.println(F("------------------------------------"));
  Serial.println(F("Temperature Sensor"));
  Serial.print  (F("Sensor Type: ")); Serial.println(sensor.name);
  Serial.print  (F("Driver Ver:  ")); Serial.println(sensor.version);
  Serial.print  (F("Unique ID:   ")); Serial.println(sensor.sensor_id);
  Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("°C"));
  Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("°C"));
  Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("°C"));
  // Print humidity sensor details.
  dht.humidity().getSensor(&sensor);
  Serial.println(F("Humidity Sensor"));
  Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("%"));
  Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("%"));
  Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("%"));
  // Set delay between sensor readings based on sensor details.
  delayMS = sensor.min_delay / 1000;
  // Delay between measurements.
  delay(delayMS);
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println(F("Error reading temperature!"));
  else {
    Serial.print(F("Temperature: "));
    Serial.print(event.temperature);
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println(F("Error reading humidity!"));
  else {
    Serial.print(F("Humidity: "));
    Serial.print(event.relative_humidity);
And here is a test for the 4digit 7 seg display:
#include <Arduino.h>
#include <TM1637Display.h>
// Module connection pins (Digital Pins)
#define CLK 2
#define DIO 3
// The amount of time (in milliseconds) between tests
#define TEST_DELAY   2000
const uint8_t SEG_DONE[] = {
	SEG_B | SEG_C | SEG_D | SEG_E | SEG_G,           // d
	SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F,   // O
	SEG_C | SEG_E | SEG_G,                           // n
	SEG_A | SEG_D | SEG_E | SEG_F | SEG_G            // E
TM1637Display display(CLK, DIO);
  int k;
  uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
  uint8_t blank[] = { 0x00, 0x00, 0x00, 0x00 };
  display.setBrightness(0x0f);
  // All segments on
  display.setSegments(data);
  delay(TEST_DELAY);
  // Selectively set different digits
  data[0] = display.encodeDigit(0);
  data[1] = display.encodeDigit(1);
  data[2] = display.encodeDigit(2);
  data[3] = display.encodeDigit(3);
  delay(TEST_DELAY);
  for(k = 3; k >= 0; k--) {
	display.setSegments(data, 1, k);
	delay(TEST_DELAY);
  display.clear();
  display.setSegments(data+2, 2, 2);
  delay(TEST_DELAY);
  display.clear();
  display.setSegments(data+2, 2, 1);
  delay(TEST_DELAY);
  display.clear();
  display.setSegments(data+1, 3, 1);
  delay(TEST_DELAY);
  // Show decimal numbers with/without leading zeros
  display.showNumberDec(0, false); // Expect: ___0
  delay(TEST_DELAY);
  display.showNumberDec(0, true);  // Expect: 0000
  delay(TEST_DELAY);
	display.showNumberDec(1, false); // Expect: ___1
	delay(TEST_DELAY);
  display.showNumberDec(1, true);  // Expect: 0001
  delay(TEST_DELAY);
  display.showNumberDec(301, false); // Expect: _301
  delay(TEST_DELAY);
  display.showNumberDec(301, true); // Expect: 0301
  delay(TEST_DELAY);
  display.clear();
  display.showNumberDec(14, false, 2, 1); // Expect: _14_
  delay(TEST_DELAY);
  display.clear();
  display.showNumberDec(4, true, 2, 2);  // Expect: 04__
  delay(TEST_DELAY);
  display.showNumberDec(-1, false);  // Expect: __-1
  delay(TEST_DELAY);
  display.showNumberDec(-12);        // Expect: _-12
  delay(TEST_DELAY);
  display.showNumberDec(-999);       // Expect: -999
  delay(TEST_DELAY);
  display.clear();
  display.showNumberDec(-5, false, 3, 0); // Expect: _-5_
  delay(TEST_DELAY);
  display.showNumberHexEx(0xf1af);        // Expect: f1Af
  delay(TEST_DELAY);
  display.showNumberHexEx(0x2c);          // Expect: __2C
  delay(TEST_DELAY);
  display.showNumberHexEx(0xd1, 0, true); // Expect: 00d1
  delay(TEST_DELAY);
  display.clear();
  display.showNumberHexEx(0xd1, 0, true, 2); // Expect: d1__
  delay(TEST_DELAY);
	// Run through all the dots
	for(k=0; k <= 4; k++) {
		display.showNumberDecEx(0, (0x80 >> k), true);
		delay(TEST_DELAY);
  // Brightness Test
  for(k = 0; k < 4; k++)
	data[k] = 0xff;
  for(k = 0; k < 7; k++) {
    display.setBrightness(k);
    delay(TEST_DELAY);
  // On/Off test
  for(k = 0; k < 4; k++) {
    display.setBrightness(7, false);  // Turn off
    delay(TEST_DELAY);
    display.setBrightness(7, true); // Turn on
    delay(TEST_DELAY);
  // Done!
  display.setSegments(SEG_DONE);
  while(1);
Probably trivial if you know what you are doing, but I'm not advanced enough to get it working. So if this do able for you name your price and I'll be happy to PayPal your fee if the code works for me.
I am an Arduino fan (so I am not a professional programmer). Aniways I am sure that I'll do it successfully.
I need:
  1. not less than 2 days from when you answere me (in this period I am full of things to do)
  2. a description of what do you wanna see on the display
  3. that you try all code I pass you (I have not the correct hardware, so I can try nothing).
  4. at the and of the project my fee is 30 euros or dollars (u can choose, I prefere the first).
Send me a PM if I can be your man
How do you plan to send the hardware?
Hi
Check PM... But a quick question :
  • if temp is 23 degree and RH is 45 the display should show 2345?
mugambi:
Hi
If at all possible it would be cool to show humidity 50.20 for example on 1 display and temp 23.50 on a second. I know the segment displays can be addressed as slave0 and slave1. But I'm equally happy if both values are shown on 1 display but alternating maybe...
77slevin:
We can have the two i think...
@sl
77slevin:
It probably doesn't matter but which [Arduino] board are you using?
