I have made a DC-DC converter using a LM2596S-5 regulator. The input is 12 V DC.
I thought PWM converters should have high degree of efficiency (hence low power dissipation), but even with 10mA load the regulator is a bit warm. I can touch it without big problems, but a few degrees warmer and I cannot touch it any more. Estimated somewhere between 50 and 60 deg C.
Have you layed your circuit out as suggested by the datasheet?
Layout on SMPS is very important due to the high frequency nature of the regulators operation.
NOTE; The wide tracks and large ground plane area?
Yes, I have. At least when it come to the components close to it. My modification is the fuse, a red led indicating blown fuse and a constant current driving a green led indicating that the fuse is OK and that the regulator have input power.
The regulator is on a prototype board and the I use AWG22 wires for the ground and VCC (from 12 V input to the output).
Here is an image (sorry about the size, my PhotoShop PC died yesterday).
I think there is a mass of info in the application data sheet about layout, this one emphasizing the conductors that need to be big and close to the 2596 pins.
