warning about Serial.read()
Any ideas what this warning means!
"narrowing conversion of 'Serial.HardwareSerial::read()' from 'int' to 'byte {aka unsigned char}'"
Below is the full warning.
C:\Users\in4si\Desktop\iFlag_WS2812B_v1\iFlag_WS2812B_v1.ino: In function 'void serialEvent()':
C:\Users\in4si\Desktop\iFlag_WS2812B_v1\iFlag_WS2812B_v1.ino:166:20: warning: narrowing conversion of 'Serial.HardwareSerial::read()' from 'int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
         Serial.read(),      // (FF) Command trigger byte
Thanks
Don't know. It might be obvious from your code, so please post it, don't forget the code tags.
Serial.read returns an int. You are assigning the return value to a byte. The warning use telling you that you may lose bit. This is not a problem if you are simply trying to get the character value returned. It is a warning, not an error.
Yes, you are right.
Thanks a million... :slight_smile:
Below is my code...
 byte command[ 4 ] =
        Serial.read(),      // (00-FE) Command id
        Serial.read(),      // (00-FE) Command value
        Serial.read()       // (00-FE) Command extra value
If you know the conversion is safe (e.g., the code checks that there are 4 bytes to read in the buffer), you can silence the warning by casting to byte:
byte command[4] =
  (byte)Serial.read(),      // (FF) Command trigger byte
  (byte)Serial.read(),      // (00-FE) Command id
  (byte)Serial.read(),      // (00-FE) Command value
  (byte)Serial.read()       // (00-FE) Command extra value
Yes, no more warnings.
Thank you.
Are you making sure there are 4 bytes in the buffer before you read it?
Presumably the reason the return value is an int, the return value will be -1 when the buffer is empty:
Returns
The first byte of incoming serial data available (or -1 if no data is available). Data type: int.
Best to make sure Serial.available() >= 4 before reading four bytes. Serial.available() returns the number of bytes available for reading.
