" warning: "B1" redefined" can't upload code to Nano
Hello,
I can’t upload the code to my Arduino Nano, the IDE gets stuck when saying “uploading” or “sending” the code to the Nano, the only warning I get is this one:
D:\Users\abelt\Documents\Arduino\NanoChargerOff_V2\NanoChargerOff_V2.ino:13:0: warning: "B1" redefined
 #define B1  13 //Corresponde a R (LED Vermelho)
In file included from C:\Users\abelt\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/Arduino.h:32:0,
                 from sketch\NanoChargerOff_V2.ino.cpp:1:
C:\Users\abelt\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/binary.h:31:0: note: this is the location of the previous definition
 #define B1 1
The code is the following:
#define S0 8
#define S1 7
#define S2 10
#define S3 11
#define sensorOut 9
//OE liga a  ???
#define RLED  14
#define GLED  15
#define BLED  16
#define WLED  17
#define B2  18 //Corresponde a G (LED verde)
#define B3  19  //Corresponde a B (LED azul)
#define Rele 12
int frequency = 0;
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(sensorOut, INPUT);
  // Setting frequency-scaling to 20%
  digitalWrite(S0,HIGH);
  digitalWrite(S1,LOW);
  pinMode(RLED, OUTPUT);
  pinMode(GLED, OUTPUT);
  pinMode(BLED, OUTPUT);
  pinMode(WLED, OUTPUT);
  pinMode(B1, INPUT); //-> RED
  pinMode(B2, INPUT); //-> GREEN
  pinMode(B3, INPUT); //-> BLUE
  pinMode(Rele, OUTPUT);
  digitalWrite(Rele, HIGH);
  static  byte LEDs[] = {RLED, GLED, BLED, WLED};
  static  byte Button[] = {B1, B2, B3};
  static  int triggerColor = 0;
  if(triggerColor == 0)
    digitalWrite(LEDs[0,1,2], HIGH);
    while(triggerColor == 0)
      int i;
      for(i = 0; i < 3; i++)
        if(digitalRead(Button[i]) == HIGH)
          while(digitalRead(Button[i]) == HIGH);
          triggerColor = i + 1;
          digitalWrite(Button[0,1,2], LOW);
          digitalWrite(Button[i], HIGH);
          digitalWrite(Button[i], LOW);
  if(triggerColor == 1)
    // Setting red filtered photodiodes to be read
    digitalWrite(S2,LOW);
    digitalWrite(S3,LOW);
    // Reading the output frequency
    frequency = pulseIn(sensorOut, LOW);
    // Printing the value on the serial monitor
    Serial.print("R= ");//printing name
    Serial.print(frequency);//printing RED color frequency
    Serial.print("  ");
    delay(100);
  else if(triggerColor == 2)
    // Setting Green filtered photodiodes to be read
    digitalWrite(S2,HIGH);
    digitalWrite(S3,HIGH);
    Serial.print("G= ");//printing name
    Serial.print("  ");
    delay(100);
  else if(triggerColor == 3)
    // Setting Blue filtered photodiodes to be read
    Serial.print("B= ");//printing name
    Serial.println("  ");
    delay(100);
  int TriggerValue = 2000;  //Valor por defeito para o gatilho
  //Cód para desligar Relé:
  if(frequency >= TriggerValue)
    digitalWrite(Rele, LOW);
    delay(5000);
  //Cód para ajustar intensidade do gatilho
  if(digitalRead(B2) == HIGH)
    while(1)
        if(triggerColor == 1) { ReadR(); }
        else if(triggerColor == 2) { ReadG(); }
        else if(triggerColor == 3) { ReadB(); }
        static int bright;
        if(frequency > 255)
          analogWrite(WLED, 100);
          bright = (frequency/5);
          analogWrite(WLED, 0);
          bright = frequency;
        analogWrite(LEDs[(triggerColor -1)], bright);
        if(digitalRead(B2) == HIGH) //Se o intensidade for selecionada
          TriggerValue = frequency; //O valodr do gatilho é registado
          digitalWrite(LEDs[0,1,2,3], LOW); //desligam-se todos os LEDs
          int o;
          for(o = 0; o < 4; o++)  //Ligam-se todos os LEDs 1 a 1
            digitalWrite(LEDs[o], HIGH);
            delay(250);
          digitalWrite(LEDs[0,1,2,3], LOW); //e desligam-se todos os LEDs outra vez,
                                            //isto para sinalizar que uma intensidade foi escolhida
        if(digitalRead(B1) == HIGH)
        else if(digitalRead(B3) == HIGH)
  //redefinir cores
    triggerColor = 0;
  //testar so o sensor deteta uma cor
    while(digitalRead(B3) == HIGH);
    while(1)
      static int i;
      if(i == 0) { ReadR(); }
      else if(i == 1) { ReadG(); }
      else if(i == 2) { ReadB(); }
      else if(i >= 3) { i = 0; }
      static int bright;
      if(frequency > 255)
        bright = frequency;
      analogWrite(LEDs[i], bright);
      i++;
    } //fim de while(1)
  delay(3000);
void ReadR()
    Serial.print("  ");
    delay(100);
void ReadG()
    Serial.print("  ");
    delay(100);
void ReadB()
    delay(100);
Don't use B1, B11, B10 etc - they're all predefined as binary literals by Arduino
Okay, I changed them from B1, B2, B3 to Button1, Button2, Button3
but now when I try to upload the code this message:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x54
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x54
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x55
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x09
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3d
This is the “new” code:
#define S0 8
#define S1 7
#define S2 10
#define S3 11
#define sensorOut 9
//OE liga a  ???
#define RLED  14
#define GLED  15
#define BLED  16
#define WLED  17
#define Button1  13 //Corresponde a R (LED Vermelho)
#define Button2  18 //Corresponde a G (LED verde)
#define Button3  19  //Corresponde a B (LED azul)
#define Rele 12
int frequency = 0;
  pinMode(Button1, INPUT); //-> RED
  pinMode(Button2, INPUT); //-> GREEN
  pinMode(Button3, INPUT); //-> BLUE
  static  byte Button[] = {Button1, Button2, Button3};
      int i;
    Serial.print("  ");
    delay(100);
    Serial.print("  ");
    delay(100);
    delay(100);
    delay(5000);
  if(digitalRead(Button2) == HIGH)
    while(1)
        static int bright;
        if(frequency > 255)
          bright = frequency;
        if(digitalRead(Button2) == HIGH) //Se o intensidade for selecionada
          int o;
            delay(250);
        if(digitalRead(Button1) == HIGH)
        else if(digitalRead(Button3) == HIGH)
  //redefinir cores
    triggerColor = 0;
    while(digitalRead(Button3) == HIGH);
    while(1)
      static int i;
      static int bright;
      if(frequency > 255)
        bright = frequency;
      i++;
    } //fim de while(1)
  delay(3000);
void ReadR()
    Serial.print("  ");
    delay(100);
void ReadG()
    Serial.print("  ");
    delay(100);
void ReadB()
    delay(100);
To save yourself in future, think about including the comment in the literal name.
So, instead of B1, how about
#define LEDVermelho 13
In that way, your code is much easier to read.
I'm sorry, I haven't translated the comments to English.
The "//Corresponde a R (LED Vermelho)" translated to English means "Matches to a R (Red LED)", the pin 13 it is just a button in front of a LED.
Wait, I just needed to use the Old bootloader for this board.
Thank you for everything AWOL! :slight_smile:
