Hopefully THIS problem will be easy to solve. I can't figure out what I'm doing wrong to get the warning msg shown at the bottom of the code. I need the array to be global as it will be changed in several parts of my project. This example was created and compiled to simplify showing the problem. I've gone through the forum for related posts for this error but don't seem to find anything that seems to match my situation (I think...)
Thanks in advance.
char MyArray [15];
MyArray [12] = {"Hello World"};
void loop() {}
// sketch_mar19a\sketch_mar19a.ino: In function 'void setup()':
// sketch_mar19a\sketch_mar19a.ino:5:32: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
// MyArray [12] = {"Hello World"};
Thanks. I've avoided using the string library since I read it was not a good idea to use on an Uno... How important do you think this really is ? My project is using caller ID data (~30 bytes) x 3 arrays and I'm basically doing copy and compare functions (so far without using string functions).
"paranoid" is good. Countless computers have been hacked by violating array or memory bounds, using one technique or another, and the problem will never go away.
