Ich versuche gerade für den attiny817 mit megatinycore einen Beispielcode von SparkFun_STUSB4500 zu kompilieren und bekomme diese Warnung, sie erscheint nicht wenn ich DEFAULT zu DEFAULT1 oder was auch immer ändere (in Datei stusb4500_register_map.h), jedoch weiß ich nicht was das für Auswirkungen haben wird, da ich das "SparkFun Power Delivery Board - USB-C (Qwiic)" erst bekomme aber schon vorab das verstehen will...
Hier der Fehler:
In file included from sketch\SparkFun_STUSB4500.h:31:0,
from D:\pcb\SparkFun Power Delivery Board\Example1-ReadParameters\Example1-ReadParameters.ino:23:
sketch\stusb4500_register_map.h:1:0: warning: "DEFAULT" redefined
#define DEFAULT 0xFF
In file included from sketch\Example1-ReadParameters.ino.cpp:1:0:
C:\Users\xxx\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10\cores\megatinycore/Arduino.h:117:0: note: this is the location of the previous definition
#define DEFAULT ADC_REFSEL_VDDREF_gc
from sketch\SparkFun_STUSB4500.cpp:21:
In file included from sketch\SparkFun_STUSB4500.h:25:0,
und hier der recht simple Code:
#include <Wire.h>
#include "SparkFun_STUSB4500.h"
STUSB4500 usb;
Wire.begin(); //Join I2C bus
/* The Power Delivery board uses the settings with address 0x28 using Wire.
Opionally, if the address jumpers are modified, or using a different I2C bus,
these parameters can be changed here. E.g. usb.begin(0x29,Wire1)
It will return true on success or false on failure to communicate. */
if(!usb.begin())
Serial.println("Cannot connect to STUSB4500.");
Serial.println("Is the board connected? Is the device ID correct?");
while(1);
Serial.println("Connected to STUSB4500!");
delay(100);
/* Read the Power Data Objects (PDO) highest priority (1-3) */
Serial.print("PDO Number: ");
Serial.println(usb.getPdoNumber());
/* Read settings for PDO1
- Voltage fixed at 5V
- Current value for PDO1 0-5A, if 0 used, FLEX_I value is used
- Under Voltage Lock Out fixed at 3.3V (but will always return 0)
- Over Voltage Lock Out 5-20%
Serial.print("Voltage1 (V): ");
Serial.println(usb.getVoltage(1));
Serial.print("Current1 (A): ");
Serial.println(usb.getCurrent(1));
Serial.print("Lower Voltage Tolerance1 (%): ");
Serial.println(usb.getLowerVoltageLimit(1));
Serial.print("Upper Voltage Tolerance1 (%): ");
Serial.println(usb.getUpperVoltageLimit(1));
/* Read settings for PDO2
- Voltage 5-20V
- Current value for PDO2 0-5A, if 0 used, FLEX_I value is used
- Under Voltage Lock Out 5-20%
Serial.print("Voltage2 (V): ");
Serial.println(usb.getVoltage(2));
Serial.print("Current2 (A): ");
Serial.println(usb.getCurrent(2));
Serial.print("Lower Voltage Tolerance2 (%): ");
Serial.println(usb.getLowerVoltageLimit(2));
Serial.print("Upper Voltage Tolerance2 (%): ");
Serial.println(usb.getUpperVoltageLimit(2));
/* Read settings for PDO3
- Voltage 5-20V
- Current value for PDO3 0-5A, if 0 used, FLEX_I value is used
Serial.print("Voltage3 (V): ");
Serial.println(usb.getVoltage(3));
Serial.print("Current3 (A): ");
Serial.println(usb.getCurrent(3));
Serial.print("Lower Voltage Tolerance3 (%): ");
Serial.println(usb.getLowerVoltageLimit(3));
Serial.print("Upper Voltage Tolerance3 (%): ");
Serial.println(usb.getUpperVoltageLimit(3));
/* Read the flex current value (FLEX_I) */
Serial.print("Flex Current: ");
Serial.println(usb.getFlexCurrent());
/* Read the External Power capable bit */
Serial.print("External Power: ");
Serial.println(usb.getExternalPower());
/* Read the USB Communication capable bit */
Serial.print("USB Communication Capable: ");
Serial.println(usb.getUsbCommCapable());
/* Read the POWER_OK pins configuration */
Serial.print("Configuration OK GPIO: ");
Serial.println(usb.getConfigOkGpio());
/* Read the GPIO pin configuration */
Serial.print("GPIO Control: ");
Serial.println(usb.getGpioCtrl());
/* Read the bit that enables VBUS_EN_SNK pin only when power is greater than 5V */
Serial.print("Enable Power Only Above 5V: ");
Serial.println(usb.getPowerAbove5vOnly());
/* Read bit that controls if the Source or Sink device's
operating current is used in the RDO message */
Serial.print("Request Source Current: ");
Serial.println(usb.getReqSrcCurrent());
Danke euch,
LG
Patrick
