warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Hi im doing that project but im having that error :
How can i solve it ?
is in line 5 :
Servo myservo; //declares servo
Password password = Password( "0000" ); //password to unlock, can be changed
More details about project
http://www.instructables.com/id/Arduino-door-lock-with-password/
#include <Password.h> //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include <Keypad.h> //Arduino Playground - HomePage  //tells to use keypad library
#include <Servo.h> //tells to use servo library
const byte ROWS = 4; // Four rows
const byte COLS = 4; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  Serial.write(254);
  Serial.write(0x01);
  delay(200);
  pinMode(11, OUTPUT);  //green light
  pinMode(12, OUTPUT);  //red light
  myservo.attach(13); //servo on digital pin 9 //servo
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  keypad.getKey();
  myservo.write(0);
  //take care of some special events
  void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
  Serial.print("Enter:");
  Serial.println(eKey);
  delay(10);
  Serial.write(254);
  switch (eKey){
    case '*': checkPassword(); delay(1); break;
    case '#': password.reset(); delay(1); break;
    default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){  //if password is right open
    Serial.println("Accepted");
    Serial.write(254);delay(10);
    //Add code to run if it works
    myservo.write(150); //deg
        digitalWrite(11, HIGH);//turn on
    delay(5000); //wait 5 seconds
    digitalWrite(11, LOW);// turn off
}else{
    Serial.println("Denied"); //if passwords wrong keep locked
    //add code to run if it did not work
    myservo.write(0);
    digitalWrite(12, HIGH); //turn on
    delay(500); //wait 5 seconds
    digitalWrite(12, LOW);//turn off
That is NOT an error. It CLEARLY says "warning".
But my project isnt working ...
(deleted)
(deleted)
To get rid of that warning, change the "char *" declaration to "const char *". From the looks of the code the declaration of "Password" is the problem.
That warning won't cause the code to fail so there must be a mistake elsewhere.
I have get this message when trying to upload Lynxmotion Hexapod code to botboarduino. It hasn't caused any trouble with my boy or my IDE so I just ignore it.
