warning: 'EEPROM' defined but not used
Hi!
I have this header file for an class to manipulate some data using eeprom.
#include <EEPROM.h>
#define _getLimit() EEPROM.get(0, _c)
class MyData{
In cpp file i use macros defined in header.
When i try to compile i got this error:
warning: 'EEPROM' defined but not used [-Wunused-variable]
I don’t know why because in macro definition i use static EEPROM method.
How can solve this?
Thanks in advance!
Remove the () in your define as you don't have any parameters and give it another go
What is _c ?
vlad2005: When i try to compile i got this error:
[u]warning[/u]: 'EEPROM' defined but not used [-Wunused-variable]
You have posted a warning message. In some case, such as your case, they can be ignored.
Fixed! After read more i found that this is an bad using of static class. Is like i'm cloning original class, witch is obviously bad, at least in this case. So I deleted macro definitions from header file and move include directive inside cpp file. Now warning is gone. Then in all methods i use static methods from EEPROM class.
@J-M-L Reading C docs, for function like macro, even if no parameter i see that () are used. I already modified source and donţt want to go back, but i don't think that will work
@Coding Badly Sorry, i typed wrong. Is an warning.
