WARNING: Error loading hardware folder C:
Hi
When I open my library manager I get a list of error messages (shown below) I think there is a problem with my HARDWARE folder. I am using IDE 1.8.7 and an Arduino Uno.
Thanks
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Board_Detector. Is it pre-1.5?
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Board_Programmer. Is it pre-1.5?
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Fuse_Calculator. Is it pre-1.5?
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Hex_Uploader. Is it pre-1.5?
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Hex_Uploader_Fixed_Filename. Is it pre-1.5?
Could not find boards.txt in C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\Atmega_Self_Read_Signature. Is it pre-1.5?
WARNING: Error loading hardware folder C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master
  No valid hardware definitions found in folder arduino_sketches-master.
You put a bunch of sketches into the hardware folder under your sketchbook. That tells the IDE that they contain a third party board package (for adding support for additional boards to the IDE), when they're actually sketches.
Move C:\Users\andy\Documents\Arduino\hardware\arduino_sketches-master\ folder and it's contents to C:\Users\andy\Documents\Arduino
That fixed it ! Thanks
