johnwasser:
Odd that the message shows up. The variable being put into PROGMEM is initialized:
It depends on what "initialized" means. If it means initialized data, i.e. data that is copied from
flash to RAM during startup to "initialize" the variable, then no, it is not an initialized data variable.
My question, is if you do this, does it break the linker optimization, -fdata-sections so that
unused progem data will now end up in flash.
It should be easy to run a test to see.
Is this solution still supposed to work for ide 1.0.5? I tried it but still get the warnings... :S
I'm implementing a webserver, using F() and PSRT() everywere... Feels like watching a horror gory movie with all the red coming from everywere!
