Hello, I started a project and encountered a problem. I am quite new to writing code for this please for help.
Here's the error :
\Arduino\libraries\AVCLanDrv\AVCLanDrv.cpp: In member function 'void AVCLanDrv::getActionID2()':
\Arduino\libraries\AVCLanDrv\AVCLanDrv.cpp:84:58: warning: invalid conversion from 'const AvcInMessageTable*' to 'AvcInMessageTable*' [-fpermissive]
avclan.actionID = avclan.getActionID(mtMain, mtMainSize);
In file included from \Arduino\libraries\AVCLanDrv\AVCLanDrv.cpp:7:0:
\Arduino\libraries\AVCLanDrv\AVCLanDrv.h:130:8: note: initializing argument 1 of 'byte AVCLanDrv::getActionID(AvcInMessageTable*, byte)'
byte getActionID (AvcInMessageTable messageTable[], byte mtSize);
Here is part of code AVCLanDrv.cpp
static const AvcInMessageTable mtMain[] PROGMEM = {
{ACT_SCAN_ON, 0x04, {0x00, 0x25, 0x43, 0xA6}},
{ACT_SCAN_D_ON, 0x04, {0x00, 0x25, 0x43, 0xA9}},
{ACT_REPEAT_ON, 0x04, {0x00, 0x25, 0x43, 0xA0}},
{ACT_REPEAT_D_ON, 0x04, {0x00, 0x25, 0x43, 0xA3}},
{ACT_RANDOM_ON, 0x04, {0x00, 0x25, 0x43, 0xB0}},
{ACT_RANDOM_D_ON, 0x04, {0x00, 0x25, 0x43, 0xB3}},
const byte mtMainSize = sizeof(mtMain) / sizeof(AvcInMessageTable);
void AVCLanDrv::getActionID2(){
// Use the last received message to determine the corresponding action ID
byte AVCLanDrv::getActionID(AvcInMessageTable messageTable[], byte mtSize){
if (slaveAddress != deviceAddress && slaveAddress != 0x0FFF) return ACT_NONE;
for (byte msg = 0; msg < mtSize; msg++){
bool found = true;
if (dataSize != pgm_read_byte_near(&messageTable[msg].dataSize)){
continue;
for (byte i = 0; i < dataSize; i++){
if (message[i] != pgm_read_byte_near(&messageTable[msg].data[i])){
found = false;
if (found){
return pgm_read_byte_near(&messageTable[msg].actionID);
return ACT_NONE;
AVCLanDrv avclan;
in H file :
typedef enum{
ACT_SCAN_ON,
ACT_SCAN_OFF,
ACT_SCAN_D_ON,
ACT_SCAN_D_OFF,
ACT_REPEAT_ON,
ACT_REPEAT_OFF,
ACT_REPEAT_D_ON,
ACT_REPEAT_D_OFF,
ACT_RANDOM_ON,
ACT_RANDOM_OFF,
ACT_RANDOM_D_ON,
ACT_RANDOM_D_OFF,
} AvcActionID;
typedef struct
byte actionID; // Action id
byte dataSize; // message size (bytes)
byte data[12]; // message
} AvcInMessageTable;
class AVCLanDrv{
public:
byte getActionID (AvcInMaskedMessageTable messageTable[], byte mtSize);
void getActionID2(); // get action id by recieved message, obligatory method
void processAction(AvcActionID); // process action, obligatory method
