I'm struggling a bit with this code
#include <UTFT.h>
#include <URTouch.h>
#include <Keyboard.h>
UTFT myGLCD(CTE32_R2,38,39,40,41);
URTouch myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
// big font chars are 16x16
extern uint8_t BigFont[];
// 320px x 240x
// btn's are 90x60
int x,y;
int activeBtn = 0;
int btnX[] = {15, 115, 215, 15, 115, 215, 15, 115, 215,};
int btnY[] = {20, 20, 20, 90, 90, 90, 160, 160, 160};
// The the value of each index in btnLabel should match the value of the same index in btnVal
// ex: when the "Main" btn is pressed, we take it's index (0) and match it in btnVal[0], so the arduino sends "KEY_F13"
String btnLabel[] = {"Main","Over","Soldr","Laser","Mill","Routr","BRB","End","Empty"};
word btnVal[] = { "KEY_F13","KEY_F14","KEY_F15","KEY_F16","KEY_F17","KEY_F18","KEY_F19","KEY_F20","KEY_F21" };
** Custom functions **
void drawButton(int btn, word color, word backColor, bool active=false)
// clear the button area
myGLCD.setColor(VGA_BLACK);
myGLCD.setBackColor(VGA_BLACK);
myGLCD.fillRoundRect(btnX[btn],btnY[btn], btnX[btn]+90, btnY[btn]+60);
if (active==true)
myGLCD.setColor(backColor);
myGLCD.setColor(color);
myGLCD.setBackColor(backColor);
myGLCD.drawRoundRect(btnX[btn],btnY[btn], btnX[btn]+90, btnY[btn]+60);
myGLCD.print(btnLabel[btn], btnX[btn]+45-(btnLabel[btn].length()*8), btnY[btn]+30-8);
void sendDebugMsg(String msg)
myGLCD.setColor (VGA_BLACK);
myGLCD.print(" ", CENTER, 2);
myGLCD.setColor(255, 255, 255);
myGLCD.print(msg, CENTER, 2);
** Required functions **
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
myGLCD.setFont(BigFont);
myGLCD.setBackColor(0, 0, 255);
for (int i=0; i < 9; i++) {
drawButton(i,VGA_LIME,VGA_BLACK);
Keyboard.begin();
if (myTouch.dataAvailable()){
myTouch.read();
x=myTouch.getX();
y=myTouch.getY();
for (int i = 0; i < 9; i++){
if (y >= btnY[i] && y <= btnY[i]+60){
for (int j = i; j <= i+2; j++){
if (x >= btnX[j] && x <= btnX[j]+90){
int btn = i+(j-i);
//sendDebugMsg(String(x)+":"+String(y)+" btn:"+String(btn));
while (myTouch.dataAvailable())
myTouch.read();
// Deactivate active button
drawButton(activeBtn, VGA_LIME, VGA_BLACK);
// Set button background to green and text black
drawButton(btn, VGA_BLACK, VGA_LIME, true);
activeBtn = btn;
// send button (i+(j-i)) value to computer
Keyboard.press(KEY_F13);
delay(100);
Keyboard.release(KEY_F13);
When I verify it, these errors come up
C:\Users\name\Downloads\obscene_deck-master\obscene_deck-master\obscene_deck\obscene_deck.ino:22:109: warning: invalid conversion from 'const char*' to 'word {aka unsigned int}' [-fpermissive]
C:\Users\name\Downloads\obscene_deck-master\obscene_deck-master\obscene_deck\obscene_deck.ino: In function 'void sendDebugMsg(String)':
C:\Users\name\Downloads\obscene_deck-master\obscene_deck-master\obscene_deck\obscene_deck.ino:55:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
And can not figure out how to fix it just tried trying to google, but do not think exactly it helps
