Hi! I've been trying to connect a ESP8266-01 wifi module to Thinkspeak software, but I keep getting the same warning and error, despite I've tried to change it.
Please help me solve it ![]()
CODE:
#include <SoftwareSerial.h>
#define RX 2
#define TX 3
String AP = "BIOTECHNOLOGY"; // AP NAME
String PASS = "biotechnology2022"; // AP PASSWORD
String API = "XANUNQA51PTLB5KW"; // Write API KEY
String HOST = "api.thingspeak.com";
String PORT = "80";
String field = "field1";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int valSensor = 1;
SoftwareSerial esp(RX,TX);
esp.begin(115200);
sendCommand("AT",5,"OK");
sendCommand("AT+CWMODE=1",5,"OK");
sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK");
valSensor = getSensorData();
String getData = "GET /update?api_key="+ API +"&"+ field +"="+String(valSensor);
sendCommand("AT+CIPMUX=1",5,"OK");
sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK");
sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
esp.println(getData);delay(1500);countTrueCommand++;
sendCommand("AT+CIPCLOSE=0",5,"OK");
int getSensorData(){
return random(1000); // Replace with your own sensor code
void sendCommand(String command, int maxTime, char readReplay[]) {
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while(countTimeCommand < (maxTime*1))
esp.println(command);//at+cipsend
if(esp.find(readReplay))//ok
found = true;
countTimeCommand++;
if(found == true)
Serial.println("OYI");
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
WARNING AND ERROR:
C:\Users\camia\Downloads\esp4\esp4.ino: In function 'void setup()':
C:\Users\camia\Downloads\esp4\esp4.ino:20:22: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
20 | sendCommand("AT",5,"OK");
C:\Users\camia\Downloads\esp4\esp4.ino:21:31: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
21 | sendCommand("AT+CWMODE=1",5,"OK");
C:\Users\camia\Downloads\esp4\esp4.ino:22:57: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
22 | sendCommand("AT+CWJAP=""+ AP +"",""+ PASS +""",20,"OK");
C:\Users\camia\Downloads\esp4\esp4.ino: In function 'void loop()':
C:\Users\camia\Downloads\esp4\esp4.ino:28:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
28 | sendCommand("AT+CIPMUX=1",5,"OK");
C:\Users\camia\Downloads\esp4\esp4.ino:29:63: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
29 | sendCommand("AT+CIPSTART=0,"TCP",""+ HOST +"","+ PORT,15,"OK");
C:\Users\camia\Downloads\esp4\esp4.ino:30:60: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
30 | sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
C:\Users\camia\Downloads\esp4\esp4.ino:32:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
32 | sendCommand("AT+CIPCLOSE=0",5,"OK");
. Variables and constants in RAM (global, static), used 28900 / 80192 bytes (36%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1500 initialized variables
╠══ RODATA 1168 constants
╚══ BSS 26232 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61895 / 65536 bytes (94%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 29127 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 243528 / 1048576 bytes (23%)
╚══ IROM 243528 code in flash
esptool.py v3.0
Serial port COM11
Connecting......................................_____
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
