Warning when compiling with highest level
When compiling eeprom.h with highest level of warning compiler, I get the following warning messages
...\libraries\EEPROM\src/EEPROM.h:43:30: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const uint8_t() const { return **this; }
...\libraries\EEPROM\src/EEPROM.h:92:26: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const int() const { return index; }
To remove these two warnings, you can safely remove the first const qualifier on each line which is useless
operator uint8_t() const { return **this; }
operator int() const { return index; }
I use arduino IDE last version (1.8.5) on Windows 10 host
I do not usually use github, I prefer let you perform the job in a correct way :slight_smile:
Kind regards
