Warum lässt die T-Mobile LTE-Box keine Daten vom ESP8266 durch
Hallo an alle,
ich versuch seit Tagen mittels ESP8266 Daten an ThingSpeak zu senden. Es geht auch überall nur nicht dort wo es soll. Habe es mittlerweile mit 5 verschiedene WLAN-Router probiert alle außer die T-Mobile LTE-BOX senden die Daten problemlos.
// Following function setup the esp8266, put it in station made and
// connect to wifi access point.
void setupEsp8266()
    if(DEBUG){
      Serial.println(F("Reseting esp8266"));
    esp8266Module.flush();
    esp8266Module.println(F("AT+RST"));
    delay(7000);
    if (esp8266Module.find("OK"))
      if(DEBUG){
        Serial.println(F("Found OK"));
        Serial.println(F("Changing espmode"));
      changingMode();
      delay(5000);
      connectToWiFi();
      if(DEBUG){
        Serial.println(F("OK not found"));
// Following function sets esp8266 to station mode
bool changingMode()
    esp8266Module.println(F("AT+CWMODE=1"));
      if(DEBUG){
        Serial.println(F("Mode changed"));
      return true;
    else if(esp8266Module.find("NO CHANGE")){
      if(DEBUG){
        Serial.println(F("Already in mode 1"));
      return true;
      if(DEBUG){
        Serial.println(F("Error while changing mode"));
      return false;
// Following function connects esp8266 to wifi access point
bool connectToWiFi()
  if(DEBUG){
    Serial.println(F("inside connectToWiFi"));
  String cmd = F("AT+CWJAP=\"");
  cmd += network;
  cmd += F("\",\"");
  cmd += password;
  cmd += F("\"");
  esp8266Module.println(cmd);
  delay(15000);
    if(DEBUG){
      Serial.println(F("Connected to Access Point"));
    return true;
    if(DEBUG){
      Serial.println(F("Could not connect to Access Point"));
    return false;
// Following function sends sensor data to thingspeak.com
void updateTemp(String voltage1,String voltage2,String voltage3,String voltage4,String voltage5,String voltage6)
  String cmd = "AT+CIPSTART=\"TCP\",\"";
  cmd += IP;
  cmd += "\",80";
  delay(5000);
  if(esp8266Module.find("Error")){
    if(DEBUG){
      Serial.println(F("ERROR while SENDING"));
    return;
  cmd = GET + "&field1=" + voltage1 + "&field2=" + voltage2 + "&field3=" + voltage3 + "&field4=" + voltage4 + "&field5=" + voltage5 + "&field6=" + voltage6 + "\r\n";
  esp8266Module.print("AT+CIPSEND=");
  esp8266Module.println(cmd.length());
  delay(15000);
  if(esp8266Module.find(">"))
    esp8266Module.print(cmd);
    if(DEBUG){
      Serial.println(F("Data sent"));
  }else
    esp8266Module.println("AT+CIPCLOSE");
    if(DEBUG){
      Serial.println(F("Connection closed"));
Der Code ist jetzt auch nichts besonderes da alles per AT-Befele gesendet wird.
Hab das ganze auch schon per ESP8266 01 und USB TTL Modul im Serial Monitor getestet. Die Verbindung zur LTE-Box ist OK. Sobald es um das Senden der Daten geht ist irgendwo "der Hund begraben" :cry: :cry:
Hab auch schon an die Verschlüsselung der LTE-Box gedacht und folgende Einstellung (an der LTE-Box) ohne Erfolg probiert:
  1. WPA/WPA2
  2. WPA
  3. WPA2
  4. keine Verschlüsselung
Ich hoffe jemand von euch hat noch ne Idee was
Feitzi:
Du möchtest Daten per HTTP-Protokoll an einen Server im Internet senden, ja?
Welchen Server?
"thingspeak.com"?
Oder eine andere Adresse?
Wo kann man in Deinem Code sehen, dass Dein Client zunächst eine Verbindung mit dem Server herzustellen versucht, bevor er den GET Befehl rausknallt?
Ich sehe in Deinem Code NIRGENDS einen Versuch des Verbindungsaufbaus mit einem Thingspeak-Server im Internet. Für mich sieht das so aus als wenn Du eine GET-Anfrage ins Nirvana schickst.
Danke für die schnelle Antwort jurs.
Ja genau thingspeak.com
Sorry hab ein paar Zeilen Code unterschlagen da ich nicht davon ausgehe dass es an denen liegt.
Den Sketch hab ich von hier übernommen.
String network = "MeineSSID";
String password = "MeinPasswort";
#define IP "184.106.153.149"
String GET = "GET /update?key=XXXXXXXXXXXXXXXX";    // replace XXXX with your channel key
Der Code funktioniert ja eigentlich. Nur eben nicht mit der LTE-Box
