Warum meckert der Compiler? (Warnungen .cpp)
Ich möchte für die bidirektionelle Kommunikation die RS485_protocol lib von Nick Gammon verwenden. https://www.gammon.com.au/forum/?id=11428
Die gibt mir folgende Warnungen:
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:115:24: warning: 'current_byte' may be used uninitialized in this function [-Wmaybe-uninitialized]
           current_byte <<= 4;
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:71:8: note: 'current_byte' was declared here
   byte current_byte;
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:107:11: warning: 'first_nibble' may be used uninitialized in this function [-Wmaybe-uninitialized]
           if (first_nibble)
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:70:8: note: 'first_nibble' was declared here
   bool first_nibble;
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:122:22: warning: 'input_pos' may be used uninitialized in this function [-Wmaybe-uninitialized]
             if (crc8 (data, input_pos) != current_byte)
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:69:8: note: 'input_pos' was declared here
   byte input_pos;
/arduino-1.8.15/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_647469/sketch_nov23c.ino.elf /tmp/arduino_build_647469/sketch_nov23c.ino.eep
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:120:11: warning: 'have_etx' may be used uninitialized in this function [-Wmaybe-uninitialized]
           if (have_etx)
/Arduino/libraries/RS485_protocol/RS485_protocol.cpp:68:8: note: 'have_etx' was declared here
   bool have_etx;
Was versteht der Compiler anders, als es soll und wie lösen?
Der lib-Code ist schön kurz:
#include <RS485_protocol.h>
const byte STX = '\2';
const byte ETX = '\3';
// calculate 8-bit CRC
static byte crc8 (const byte *addr, byte len)
  byte crc = 0;
  while (len--)
    byte inbyte = *addr++;
    for (byte i = 8; i; i--)
      byte mix = (crc ^ inbyte) & 0x01;
      crc >>= 1;
      if (mix)
        crc ^= 0x8C;
      inbyte >>= 1;
      }  // end of for
    }  // end of while
  return crc;
}  // end of crc8
// send a byte complemented, repeated
// only values sent would be (in hex):
//   0F, 1E, 2D, 3C, 4B, 5A, 69, 78, 87, 96, A5, B4, C3, D2, E1, F0
void sendComplemented (WriteCallback fSend, const byte what)
byte c;
  // first nibble
  c = what >> 4;
  fSend ((c << 4) | (c ^ 0x0F));
  // second nibble
  c = what & 0x0F;
}  // end of sendComplemented
// send a message of "length" bytes (max 255) to other end
// put STX at start, ETX at end, and add CRC
void sendMsg (WriteCallback fSend, const byte * data, const byte length)
  fSend (STX);  // STX
  for (byte i = 0; i < length; i++)
    sendComplemented (fSend, data [i]);
  fSend (ETX);  // ETX
  sendComplemented (fSend, crc8 (data, length));
}  // end of sendMsg
// receive a message, maximum "length" bytes, timeout after "timeout" milliseconds
// if nothing received, or an error (eg. bad CRC, bad data) return 0
// otherwise, returns length of received data
byte recvMsg (AvailableCallback fAvailable,   // return available count
              ReadCallback fRead,             // read one byte
              byte * data,                    // buffer to receive into
              const byte length,              // maximum buffer size
              unsigned long timeout)          // milliseconds before timing out
  unsigned long start_time = millis ();
  bool have_stx = false;
  // variables below are set when we get an STX
  bool have_etx;
  byte input_pos;
  bool first_nibble;
  byte current_byte;
  while (millis () - start_time < timeout)
    if (fAvailable () > 0)
      byte inByte = fRead ();
      switch (inByte)
        case STX:   // start of text
          have_stx = true;
          have_etx = false;
          input_pos = 0;
          first_nibble = true;
          start_time = millis ();  // reset timeout period
        case ETX:   // end of text
          have_etx = true;
        default:
          // wait until packet officially starts
          if (!have_stx)
          // check byte is in valid form (4 bits followed by 4 bits complemented)
          if ((inByte >> 4) != ((inByte & 0x0F) ^ 0x0F) )
            return 0;  // bad character
          // convert back
          inByte >>= 4;
          // high-order nibble?
          if (first_nibble)
            current_byte = inByte;
            first_nibble = false;
            }  // end of first nibble
          // low-order nibble
          current_byte <<= 4;
          current_byte |= inByte;
          // if we have the ETX this must be the CRC
          if (have_etx)
              return 0;  // bad crc
            return input_pos;  // return received length
            }  // end if have ETX already
          // keep adding if not full
          if (input_pos < length)
            data [input_pos++] = current_byte;
            return 0;  // overflow
        }  // end of switch
      }  // end of incoming data
    } // end of while not timed out
  return 0;  // timeout
} // end of recvMsg
Die Zeilennumern oben passen zu dieser, um den Kommentarblock gekürzte, Version. Die Headerdatei als Attachment.
RS485_protocol.h (579 Bytes)
Zuweisungen an diese Variablen erfolgen nur in Entscheidungsabfragen (z.B. if, switch-case). Wenn keine zutrifft, ist der Wert unbestimmt.
Gruß Tommy
Die Meldung ist doch offensichtlich und klar.
Was verstehst du daran nicht?
Was hält dich davon ab, die betreffenden Variablen zu initialisieren?
Bemerke:
Uninitialisierte Variablen sind schon fast Zufallsgeneratoren.
Möchtest du einen solchen Zufallsgenerator nutzen?
Auch ich halte das für eine windelweiche Ausrede, keine verbindliche Zusicherung. Einfach Startwerte an die Variablen zuweisen und gut ist.
Klar doch...
Manchmal ist das eben komisch.
