"was not declared in this scope" - help needed
I'm trying to make a project where something gets written down on the LCD when the threshold temperature is met, my issue is that I get this error.
C:\Users\Marin\Documents\Arduino\RELEJ_TEMP_VENT_-AUTOMATIKA\RELEJ_TEMP_VENT-_AUTOMATIKA.ino: In function 'void setup()':
RELEJ_TEMP_VENT_-_AUTOMATIKA:20: error: 'dht' was not declared in this scope
dht.begin();
C:\Users\Marin\Documents\Arduino\RELEJ_TEMP_VENT_-AUTOMATIKA\RELEJ_TEMP_VENT-_AUTOMATIKA.ino: In function 'void loop()':
RELEJ_TEMP_VENT_-_AUTOMATIKA:30: error: 't' was not declared in this scope
lcd.print(t);
RELEJ_TEMP_VENT_-_AUTOMATIKA:53: error: 'plus' was not declared in this scope
if (t = plus) {
exit status 1
#include <DHT.h>
#define DHTPIN 12
#define DHTTYPE DHT11
#include <Wire.h>
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int buttonPin2 = 3;
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
pinMode(buttonPin2, INPUT);
lcd.begin(16,2);
dht.begin();
static int stock = 20;
// read the state of the pushbutton value:
lcd.print("Temperatura: ");
lcd.print(t);
lcd.print("C");
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
int t = dht.readTemperature();
if (buttonState == HIGH) {
delay(250);
int plus = ++stock;
lcd.setCursor(0, 1);
lcd.print("On temp: ");
lcd.print(plus);
buttonState = digitalRead(buttonPin2);
delay(250);
int plus = --stock;
lcd.setCursor(0, 0);
lcd.print("Number: ");
lcd.print(plus);
if (t = plus) {
lcd.setCursor(0,1);
lcd.print("VENT. SPINS");
Thanks in advance!!
  if (t = plus) {==
You have no object called "dht"
If you look at the example code that came with the library, you'll find help there.
At the top of this Forum is a post titled Useful Links. Within that is a section called C++ Programming, and within that is a section on Scope. You might find that section useful.
Alright thanks!
