was not declared in this scope
Code trying to compile :
//  Name    : shiftOutCode, Dual Binary Counters                 //
//  Author  : Carlyn Maw, Tom Igoe                               //
//  Date    : 25 Oct, 2006                                       //
//  Version : 1.0                                                //
//  Notes   : Code for using a 74HC595 Shift Register            //
//          : to count from 0 to 255                             //
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
  //Start Serial for debuging purposes
  beginSerial(19200);
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  //count up routine
  for (int j = 0; j < 256; j++) {
    //ground latchPin and hold low for as long as you are transmitting
    digitalWrite(latchPin, 0);
    //count up on GREEN LEDs
    shiftOut(dataPin, clockPin, j);
    //count down on RED LEDs
    shiftOut(dataPin, clockPin, 255-j);
    //return the latch pin high to signal chip that it
    //no longer needs to listen for information
    digitalWrite(latchPin, 1);
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
  // This shifts 8 bits out MSB first,
  //on the rising edge of the clock,
  //clock idles low
  //internal function setup
  int i=0;
  int pinState;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, OUTPUT);
  //clear everything out just in case to
  //prepare shift register for bit shifting
  digitalWrite(myDataPin, 0);
  digitalWrite(myClockPin, 0);
  //for each bit in the byte myDataOut?
  //NOTICE THAT WE ARE COUNTING DOWN in our for loop
  //This means that %00000001 or "1" will go through such
  //that it will be pin Q0 that lights.
  for (i=7; i>=0; i--)  {
    //if the value passed to myDataOut and a bitmask result
    // true then... so if we are at i=6 and our value is
    // %11010100 it would the code compares it to %01000000
    // and proceeds to set pinState to 1.
    if ( myDataOut & (1<<i) )
      pinState= 1;
      pinState= 0;
    //Sets the pin to HIGH or LOW depending on pinState
    digitalWrite(myDataPin, pinState);
    //register shifts bits on upstroke of clock pin
    digitalWrite(myClockPin, 1);
    //zero the data pin after shift to prevent bleed through
  //stop shifting
Errors gotten on make :
/home/tux/shiftout_dual_binary_counters/shiftout_dual_binary_counters.cpp:16: error: âbyteâ does not name a type
/home/tux/shiftout_dual_binary_counters/shiftout_dual_binary_counters.cpp:19: error: âbyteâ does not name a type
/home/tux/shiftout_dual_binary_counters/shiftout_dual_binary_counters.cpp:22: error: variable or field âLightâ declared void
/home/tux/shiftout_dual_binary_counters/shiftout_dual_binary_counters.cpp:22: error: âbyteâ was not declared in this scope
make: *** [/home/tux/shiftout_dual_binary_counters/shiftout_dual_binary_counters.o] Error 1
I can't see what I'm doing wrong here .. I copy/paste the code from the arduino site ...so I rekken this MUST be right ... :-/
the code compiles without errors in the arduino-ide, so its correct.
Nobody can tell whats wrong without the Makefile-contents.
Eberhard
