"Was not declared on this scope"
Hello everyone! I am trying to create a project where i will have an MQ-7 gas sensor connected to an Arduino Uno to measure CO levels. I have already created a pwm cirquit for the sensor to work and i am using pin 2 as a pwm pin. What i want is after the sensor measures, to send the data via wifi to another Arduino Uno (Using the NRF24L01+ module).
I have written the code for the "sender" Arduino but i am getting "sensorValue was not declared on this scope".
My code is"
#include <SPI.h>
#include "RF24.h"
RF24 myRadio (7, 8);
byte addresses[][6] = {"0"};
int sensorPin = A0;  // select the input pin for the CO sensor
// initialize digital pin ledPin as an output
 int ledPin = 2;
struct package
  int id=1;
  char  text[100] = "CO Level:";
  public: int sensorValue = 0; // variable to store the value coming from the sensor
typedef struct package Package;
Package data;
  myRadio.begin();
  myRadio.setChannel(115);
  myRadio.setPALevel(RF24_PA_MAX);
  myRadio.setDataRate( RF24_250KBPS ) ;
  myRadio.openWritingPipe( addresses[0]);
 pinMode(ledPin, OUTPUT);
 analogWrite(ledPin, 255);  // "HIGH" state - 5V
  delay(60000);            // HIGH" state lasts 60 seconds
 // After heating it's time to go to "LOW" state
  analogWrite(ledPin, 72);  // "LOW" state - 1.4V
  delay(90000);            // "LOW" state lasts for 90 seconds
 // Waiting 90 more seconds
  digitalWrite(ledPin, HIGH);
  delay (50); //small delay so that the sensor does not heat too much
   // Reading Sensor
 sensorValue = analogRead(sensorPin);
  myRadio.write(&data, sizeof(data));
  Serial.print("\nPackage:");
  Serial.print(data.id);
  Serial.print("\n");
  Serial.println(data.text);
  Serial.println(data.sensorValue);
  data.id = data.id + 1;
  data.temperature = data.temperature+0.1;
i am getting a exit status 1
"'sensorValue' was not declared in this scope" errir in the sensorValue = analogRead(sensorPin); line
What am i doing wrong? Can someone help me? Thanks.
P.S. Sorry about my English.
sensorValue = analogRead(sensorPin);Did you mean "data.sensorValue" ?
Oh, i just saw it too....Silly me :frowning:
Thanks a ton, i kinda went blind.
Really? Pin 2 isn't a PWM pin, so how are you doing that?
The compiler can count, too. Better than you.
