Waste Segregation
hey I want code for waste segreter....which seprate dry and wet waste using ir sensor+moisture sensor+servo and arduino
  1. Please create a post of Your own.
  2. You make the code, not we. We only assist to make the code work.
bro i am in 10th
i dont have knowledge of this
i can try to became a best programer but now i really have need
Then the first step may be a visit to Google ( or your favorite search) for "separate dry and wet waste arduino" to see what others may have done.
hey I want code for waste segreter....which seprate dry and wet waste using ir sensor+moisture sensor+servo and arduino plz help me :persevere:
This is not a free code writing service. You do the research (I pointed you to a start in your other post), make the circuit schematic, then write and test the code. Then when you have trouble, post the project's schematic, the problem code (the whole sketch), a description of what it does and how that differs from what you want and then we, gladly, help you to make the project work.
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
@ssaaddff, stop cross posting and stop hijacking.
In practical terms that means if you post anywhere but this thread about waste segregation I will permanently ban you.
Must be in 11th where they let you in on the secret seach tool google.
Knock yourself out.
a7
