Waste sorting machine
I need help with a project I'm working on—an automatic bottle sorting machine that uses inductive, capacitive, and ultrasonic sensors. The original design of the project uses NPN normally closed inductive and capacitive proximity sensors. However, I only have NPN normally open inductive and capacitive sensors. What changes might I need to make in the code to make it work with the sensors I have?
#include <Servo.h>
Servo Pipe_Servo;
Servo Gate_Servo;
// define the variables
int sensorInd = A0; //Pin A0 (analog)
int sensorpin = 2; //Digital Pin nr. 2
int indValue;
const int trigPin = 7;
const int echoPin = 8;
int i=0;
float Pipe_Pos=0.0;
float Gate_Pos=0.0;
int n=0;
long duration;
int distance;
float metalDetected;
pinMode(trigPin, OUTPUT); // trigPin=output
pinMode(echoPin, INPUT); // echoPin = input
Serial.begin(9600); // Starts the serial communication
// Codes that run only once[
//--System Initialization--
    Pipe_Pos=Pipe_Servo.read();//Read the last value given to Pipe servo
    Gate_Pos=Gate_Servo.read();//Read the last value given to Pipe servo
    Serial.println("Motor_PIPE Position");
    Serial.println(Pipe_Pos);
    Serial.println("Motor_GATE Position");
    Serial.println(Gate_Pos);
    delay(5000);
    Pipe_Servo.attach(11);
    if (Pipe_Pos<90){
      for(i=Pipe_Pos; i<=90; i=i+1){
      Pipe_Servo.write(i);
      delay(15);
      else {
        for(i=Pipe_Pos; i>=90; i=i-1){
        delay(15);
delay(1000); //Delay (wait) for servo pipe to go to the bin.
    //Next rotate the gate servo.
    //And control the speed of Gate Servo.
    Gate_Servo.attach(10);
     for(n=0; n<=45; n=n+1){  //Choose the right angle for Gate servo
      Gate_Servo.write(n);
      delay(20); //Controll the speeed of Gate servo
    delay(1000); //Delay (wait) and then bring back the Gate_Servo to its
     //initial position.
     //Bring Back Gate_Servo to initial position
     //So from actual position 2-> n=45; we go backwards up to n=0.
     for(n=45; n>=0; n=n-1){
      delay(25); //Control the speed of Gate servo
delay(5000);
//--System Initialization--//
// Codes that run only once]
//delay(100);
delay(3000);
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(10);//
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(30);//it was 1
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
indValue=analogRead(sensorInd);//Save value that is read from the analog pin A0 to the variable indValue
delay(10);
int sensorstate = digitalRead(sensorpin); // Digital value for Capacitive S.
metalDetected = (float)indValue*100/1024.0; //from analog value
delay(50);
Pipe_Pos=Pipe_Servo.read();//Read the actual position of Pipe servo
Gate_Pos=Gate_Servo.read();//Read the actual position of Gate servo
//**METAL DETECTED**/
/ if(indValue>=250 && sensorstate == 1 && distance<=14)
  if(indValue>=250){
   Serial.println("Metal Detected");
    Serial.println("Motor to metal bin");
    delay(100);
    //Wait for some time after the measurements and move servo to
    //the corresponding bin
    //For initial position of servo_gate/PIPE in this case the read function will give us the last position of servo
    //in degree
    //Go to the second position of the PIPE servo @90 degree
    //To control the speed of the servo we do this for loop.
    //We have 2 cases 1; when pipe is somewhere in position greater then 90, in this particular case we want to go to 90 so we have to loop back.
    //The other case is to loop forward i=i+1, (meaning to increase the angle in incremental manner).
    if (Pipe_Pos<90){
      delay(15);
      else {
        delay(15);
      delay(20);
    delay(1000); //Delay (wait) and then bring back the Gate_Servo to its initial position.
     //So from actual position 2--> n=45; we go backwards up to n=0.
      delay(25);
   //**METAL DETECTED**//
   //**PLASTIC DETECTED**//
   else if(indValue<=250 && sensorstate == 1 && distance<=15){ //NO NO state
   delay(100);
   Serial.println("Plastic Detected");
    Serial.println("Motor to Plastic Bin");
    delay(100);
    //in degree
    //Go to the second position of the gate Pipe_Servo in degree (145) for Plastic
    //We have 2 cases 1; when pipe is somewhere in position greater then 145, in this particular case we want to go to 145 so we have to loop back.
    //The other case is to loop forward i=i+1, (meaning to increase the angle in incremental manner)until we reach the desired angle.
    if (Pipe_Pos<145){
      for(i=Pipe_Pos; i<=145; i=i+1){
      delay(15);
      else {
        for(i=Pipe_Pos; i>=145; i=i-1){
        delay(15);
    //Next rotate the gate servo.//This remains the same for all other cases
      delay(20);
     //initial position.
     for(n=45; n>=0; n=n-1){  //Choose the right angle for Gate servo
      delay(25); //Controll the speeed of Gate servo (it can be a litle faster now)
//delay(100);
//**GLASS DETECTED**//
else if(indValue<=250 && sensorstate != 1 && distance<=14){
   Serial.println("Glass Detected");
    Serial.println("Motor to Glass Bin");
    //For initial position of servo_gate/PIPE in this case the read function will give us the last position of servo in degree
    //Go to the second position of the Pipe_Servo @25 degree for Glass
    //We have 2 cases; when pipe is somewhere in position greater then 90, in this particular case we want to go to 25 so we have to loop back.
    //Actually in this case we can have only one case when angle is greater then 25, but however! :P
    if (Pipe_Pos<25){
      for(i=Pipe_Pos; i<=25; i=i+1){
      delay(15);
      else {
        for(i=Pipe_Pos; i>=25; i=i-1){
        delay(15);
      delay(20);
     //initial position.
     //So from actual position n=45; we go backwards up to n=0.
      delay(25);
Your attempt to use code tags did not work out because you had the below at the start
[code]<br>
The <br> confused the forum software; fixed it for you. The code tags [code] and [/code]need to be on their own line.
You only have one NPN sensor on your code, the other one is analog.
Just change every sensorstate condition from 1 to 0
Also, on setup it's missing line:
pinMode(sensorpin, INPUT);
Hi, @eyyy123
Did you write this code?
If so you should be able to work out the logic changes needed.
Can you please tell us your electronics, programming, arduino, hardware experience?
Tom.... :smiley: :+1: :coffee: :australia:
What about sensorstate != 1 on glass detection, should I change it to 0
Yes, everything has to be opposite
That code does not compile.
Are you sure you posted the correct code?
I only see one digital sensor that would use an NPN output, the capacitive sensor.
The inductive sensor is an analog input and would not use a NPN output.
Tell us what sensors you are actually using.
This is the updated version of the code I sent earlier that uses an inductive and capacitive npn Normally open. Is this right?
#include <Servo.h>
Servo Pipe_Servo;
Servo Gate_Servo;
// Define the sensor pins
const int capacitiveSensorPin = 2; // NPN-NO Capacitive sensor
const int inductiveSensorPin = 3;  // NPN-NO Inductive sensor
// Define servo control and distance measurement variables
int i = 0;
int n = 0;
float Pipe_Pos = 0.0;
float Gate_Pos = 0.0;
long duration;
int distance;
  // Sensor pins setup
  pinMode(capacitiveSensorPin, INPUT_PULLUP);
  pinMode(inductiveSensorPin, INPUT_PULLUP);
  // Attach and center Pipe Servo
  Pipe_Pos = Pipe_Servo.read();
  Gate_Pos = Gate_Servo.read();
  Serial.println("Initializing System...");
  Serial.print("Pipe Servo Position: "); Serial.println(Pipe_Pos);
  Serial.print("Gate Servo Position: "); Serial.println(Gate_Pos);
  // Center the Pipe Servo to 90°
  if (Pipe_Pos < 90) {
    for (i = Pipe_Pos; i <= 90; i++) {
      delay(15);
    for (i = Pipe_Pos; i >= 90; i--) {
      delay(15);
  // Move and return Gate Servo
  for (n = 0; n <= 45; n++) {
    delay(20);
  for (n = 45; n >= 0; n--) {
    delay(25);
  delay(3000);
  delay(3000);
  // Trigger ultrasonic sensor
  distance = duration * 0.034 / 2;
  // Read sensors
  int metalState = digitalRead(inductiveSensorPin);     // 0 = metal detected
  int capacitiveState = digitalRead(capacitiveSensorPin); // 0 = object detected
  // METAL DETECTED
  if (metalState == 0) {
    movePipeTo(90);
    activateGate();
  // PLASTIC DETECTED
  else if (metalState == 1 && capacitiveState == 0 && distance <= 15) {
    movePipeTo(145);
    activateGate();
  // GLASS DETECTED
  else if (metalState == 1 && capacitiveState == 1 && distance <= 14) {
    movePipeTo(25);
    activateGate();
// Helper function to move pipe servo
void movePipeTo(int angle) {
  if (Pipe_Pos < angle) {
    for (i = Pipe_Pos; i <= angle; i++) {
      delay(15);
    for (i = Pipe_Pos; i >= angle; i--) {
      delay(15);
// Helper function to open/close gate
void activateGate() {
    delay(20);
    delay(25);
Original code copied from an HTML document.
Depends on the sensors. Are you sure they are both NPN normally open?
Are now sure this is the correct code?
Still don't look right.
Why don't you print all the sensor states here?
It's quicker to test the logic of your sensors than looking for datasheets.
The above is only used to print position, and only in setup().
The above line is executed three times before it is used.
The servos are called when proximity is greater than 14 (or 15) cm.
