watchdog error
Hello everybody.
Im new to programming. Im trying to control blinds with esp8266 via mqtt.
I can send recieve with mqtt also i use some sensors.
I tried to mix them. Control blinds (automated with light sensor and manuel with home assistans + dth sensor + ultrosonic sensor for reset blinds + store stepper count to eeprom)
i got hw watchdog error. (with and without connect any cable)
Here is my code.
#include <AccelStepper.h>
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define Motor1_Dir 5
#define Motor1_Step 6
#define DHTPIN 7
#define DHTTYPE DHT11
const char* ssid = "x";
const char* password = "x";
const char* mqtt_server = "x";
const char* mqttUser = "x";
const char* mqttPassword = "x";
long duration; //looptaki hesap için
long ilksure;  //setuptaki hesap için
int distance; //looptaki hesap için
int distancefirst;  //setuptaki hesap için
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
DHT dht(DHTPIN, DHTTYPE);
AccelStepper stepper(1, Motor1_Step, Motor1_Dir);
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
// Perde Kontrolleri
void callback(char* topic, byte* payload, unsigned int length)
    Serial.print("Message arrived [");
    Serial.print(topic);
    Serial.print("] ");
    for (int i = 0; i < length; i++)
  Serial.print((char)payload[i]);
  int val = (char)payload[i];
    if (strcmp(topic,"alkan/perdedurum")==0)
 // Automatik Mode
        if ( val = 'auto' )
             if (isik < 100 )
                  stepper.enableOutputs();
                  stepper.runToNewPosition(0);
                  ESP.wdtFeed();
                  EEPROM.write(address, '0');
                  Serial.println("Otomatik Acildi");
                  stepper.disableOutputs();
             if (isik > 800 )
                  stepper.runToNewPosition(3000);
                  ESP.wdtFeed();
                  EEPROM.write(address, '3000');
                  Serial.println("Otomatik Kapandi");
 // Manuel Mode
        if ( val = 'manuel' )
             if (strcmp(topic,"alkan/perde")==0)
                  // Perde Pozisyona Git
                   value = EEPROM.read(address);
                   val2 = value*10;
                  if ( val != val2 or val != 'STOP' or val != 'RESET' )
                  stepper.runToNewPosition(val);
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  EEPROM.write(address, valEEPROM);
                  Serial.println("Durdugu Yer");
                  Serial.print(val);
            // Acil Durdur
             if( val = 'STOP' )
                stepper.stop();
                valstop = stepper.currentPosition ();
                EEPROM.write(address, valstop);
                Serial.println("Stop Yeri");
                Serial.print(valstop);
          // Resetleme
            if( val = 'RESET' )
                   digitalWrite(trigPin, HIGH);
                   delayMicroseconds(10);
                   digitalWrite(trigPin, LOW);
                   ilksure = pulseIn(echoPin, HIGH);
                   distancefirst = ilksure*0.034/2;
                   Serial.print(distancefirst);
                  if (( distancefirst <= 50 ) and  (distancefirst >=5 ))
                     stepper.runSpeed();
                     duration = pulseIn(echoPin, HIGH);
                     distance = duration*0.034/2;
                     Serial.print(distance);
                  if (( distance >= 50 ) or  (distancefirst <=5 ))
                      stepper.stop();
//                    distancefirst = 200;
                      StepCounter = -100;
                      ESP.wdtFeed();
                      Serial.println("Resetlendi");
//                    distance = 15;
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("alkan", mqttUser, mqttPassword )) {
      Serial.println("connected");
      client.subscribe("alkan/perde");
      client.subscribe("alkan/perdedurum");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
    ESP.wdtDisable();
    pinMode(trigPin, OUTPUT);
    pinMode(echoPin, INPUT);
    setup_wifi();
    client.setServer(mqtt_server, 1883);
    dht.begin();
    stepper.setMaxSpeed(1000);
    stepper.setSpeed(900);
    isik = analogRead(A0);
    if (!client.connected())
    reconnect();
// SICAKLIK ve NEM
       float temp = dht.readTemperature();
       float humi = dht.readHumidity();
       float isik2 = analogRead(A0);
       Serial.println("Sıcaklık");
       Serial.println(temp);
       Serial.println("Nem");
       Serial.println(humi);
       Serial.println("Isik");
       Serial.println(isik2);
       client.publish("alkan/temp", String(temp).c_str());
       client.publish("alkan/humi", String(humi).c_str());
       client.publish("alkan/isik", String(isik2).c_str());
        delay(5000);
Here is my error:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
You need to call wdt.reset() at least within the wdt timeout period.
If you have a while() or for() loop running, that takes too long, you need to accommodate that in your wdt calls.
Worst case - if you have no control of the offending code, wdt.disable() just before, and wdt.enable() again as soon as you can.
I couldnt do it can you suggest a place to put reset or disable.
If i put it at the begining and never enable what will happen ?
if ( val = 'auto' )Oops
do i need " " ? It will be payload from mqtt
"val" is an int.
Now, on a 32 bit device, this could contain the multi-character constant 'auto', but since you're only reading a single character with Serial.read, it isn't a sensible choice.
i tried to change it to a number but still no luck.
We can't see what you changed
i have changed to this
#include <EEPROM.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define DHTPIN 7
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
    Serial.print("] ");
 // Automatik Mode
        if ( val = 'a' )
             if (isik < 100 )
                  ESP.wdtFeed();
             if (isik > 800 )
                  ESP.wdtFeed();
 // Manuel Mode
        if ( val = 'b' )
                   val2 = value*10;
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  Serial.print(val);
            // Acil Durdur
             if( val = 'STOP' )
                stepper.stop();
          // Resetleme
            if( val = 'RESET' )
                     stepper.runSpeed();
                      stepper.stop();
                      StepCounter = -100;
                      ESP.wdtFeed();
//                    distance = 15;
void reconnect() {
      delay(5000);
    ESP.wdtDisable();
    setup_wifi();
    dht.begin();
    reconnect();
// SICAKLIK ve NEM
        delay(5000);
int val = (char)payload[i];Lose the word "int"
i have changed to this. But still same
#include <EEPROM.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define DHTPIN 7
const char* ssid = "xxx";
const char* password = "xxx";
const char* mqtt_server = "192.168.1.60";
const char* mqttUser = "mqtt";
const char* mqttPassword = "mqtt";
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
    Serial.print("] ");
 // Automatik Mode
        if ( val = '4444' )
             if (isik < 100 )
                  ESP.wdtFeed();
             if (isik > 800 )
                  ESP.wdtFeed();
 // Manuel Mode
        if ( val = '5555' )
                   val2 = value*10;
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  Serial.print(val);
            // Acil Durdur
             if( val = 'STOP' )
                stepper.stop();
          // Resetleme
            if( val = 'RESET' )
                     stepper.runSpeed();
                      stepper.stop();
                      StepCounter = -100;
                      ESP.wdtFeed();
//                    distance = 15;
void reconnect() {
      delay(5000);
    ESP.wdtDisable();
    setup_wifi();
    dht.begin();
    reconnect();
// SICAKLIK ve NEM
        delay(5000);
if ( val = '4444' )
Oops
if( val = 'RESET' ) Oops2
Thanks for your help but still i cant do it.
New code:
#include <EEPROM.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define DHTPIN 7
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
    Serial.print("] ");
 // Automatik Mode
        if ( val = '1' )
             if (isik < 100 )
                  ESP.wdtFeed();
             if (isik > 800 )
                  ESP.wdtFeed();
 // Manuel Mode
        if ( val = '2' )
                   val2 = value*10;
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  Serial.print(val);
            // Acil Durdur
             if( val = '3' )
                stepper.stop();
          // Resetleme
            if( val = '4' )
                     stepper.runSpeed();
                      stepper.stop();
                      StepCounter = -100;
                      ESP.wdtFeed();
//                    distance = 15;
void reconnect() {
      delay(5000);
    ESP.wdtDisable();
    setup_wifi();
    dht.begin();
    reconnect();
// SICAKLIK ve NEM
        delay(5000);
= is for assignment
== is for comparison
Thank you your are a good teacher. But still no :slight_smile:
I think i need to write from begining. Can it be due to pin selection ?
#include <EEPROM.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define DHTPIN 7
const char* mqtt_server = "192.168.1.22";
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
    Serial.print("] ");
 // Automatik Mode
        if ( val == '1' )
             if (isik < 100 )
                  ESP.wdtFeed();
             if (isik > 800 )
                  ESP.wdtFeed();
 // Manuel Mode
        if ( val == '2' )
                   val2 = value*10;
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  Serial.print(val);
            // Acil Durdur
             if( val == '3' )
                stepper.stop();
          // Resetleme
            if( val == '4' )
                     stepper.runSpeed();
                      stepper.stop();
                      StepCounter = -100;
                      ESP.wdtFeed();
//                    distance = 15;
void reconnect() {
      delay(5000);
    ESP.wdtDisable();
    setup_wifi();
    dht.begin();
    reconnect();
// SICAKLIK ve NEM
        delay(5000);
I can't figure out what that loop is for.
The overall effect is equivalent to
val = (char)payload [length -1];
(ignoring the serial print)
It was like that at the example. And worked when i try mqtt. So i didn't changed.
I delete it says " 'i' was not declared in this scope "
At that section i try to get info from mqtt
    Serial.print("] ");
nope still same
#include <EEPROM.h>
#include <DHT.h>
#define trigPin 1
#define echoPin 2
#define DHTPIN 7
int StepCounter;
int value;
int val;
int val2;
int valEEPROM;
int valstop;
int address = 0;
int isik;
void setup_wifi() {
  delay(10);
    Serial.print(".");
  Serial.println("");
    Serial.print("] ");
  Serial.print((char)payload [length -1]);
 // Automatik Mode
        if ( val == '1' )
             if (isik < 100 )
                  ESP.wdtFeed();
             if (isik > 800 )
                  ESP.wdtFeed();
 // Manuel Mode
        if ( val == '2' )
                   val2 = value*10;
                  ESP.wdtFeed();
                  valEEPROM = val/10;
                  Serial.print(val);
            // Acil Durdur
             if( val == '3' )
                stepper.stop();
          // Resetleme
            if( val == '4' )
                     stepper.runSpeed();
                      stepper.stop();
                      StepCounter = -100;
                      ESP.wdtFeed();
//                    distance = 15;
void reconnect() {
      delay(5000);
    ESP.wdtDisable();
    setup_wifi();
    dht.begin();
    reconnect();
// SICAKLIK ve NEM
        delay(5000);
I'm still seeing stuff like this EEPROM.write(address, '3000');
