I´m new to 101 and need to use watchdog timer to reset the board on IOT comunications failure but I can´t see how to access it.
Any help or something to read?
Thank you!
Thank you!
the Curie TimerOne library should handle this with little modifications (since every timer can be setup as a watchdog timer).
You could open an issue on GitHub - arduino/ArduinoCore-arc32 so this functionality could be integrated in the next core APIs
Thank you facchinm for your reply but I can´t see how to reset.
We really can use TimerOne as watchdog but then how to reset the board? For now I just see the hack of wiring a digital pin to reset pin and make it happen from there.
Is there any other way of doing a reset on this board?
In the meanwhile I'll open an issue as you suggest.
Regards.
I don't know an answer for the Curie, but for other platforms, there are hacks you can do to generate a software reset of the board (an interrupt through the Power On Reset vector.) Namely, attempt to write the flash without the proper password. I am new to the Curie, so maybe this idea is way off base.
