I’ve been tearing my hair out all day on this & I finally give up.
I’m trying to implement a watchdog timer on a project, to recover from the device hanging very occasionally.
I’ve tried this on a 168 & a 328p - I’m using the ICs on a breadboard, they do not have a bootloader, and I’m programming them via a TinyISP
I found this excellent guide:
http://arduino.cc/forum/index.php/topic,63651.0.html
But since I don’t have serial, I modified the code a touch to give me visual indication of what was happening.
My code is below.
What I see is my status LED blinking, slower and slower. When it gets to around 2 secs period, the wdt_reset() doesn’t occur in time, and the watchdog kicks in.
What I then see is the LED blinking very rapidly - I think the IC has gone in to a tight reset loop.
I also tried the simpler method of enabling the timer:
wdt_reset(); // reset the WDT timer
wdt_enable(WDTO_2S); //and enable it
with the same results
Clearly I’ve messed up somewhere - can anyone point me in the right direction?
Thanks,
James
Watchdog Timer Basic Example
10 June 2011
Nicolas Larsen
#include <avr/wdt.h>
int loop_count = 0;
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
delay (500);
watchdogSetup();
void watchdogSetup(void)
cli(); // disable all interrupts
WDTCSR con?guration:
WDIE = 0: Interrupt Enable
WDE = 1 :Reset Enable
WDP3 = 0 :For 2000ms Time-out
WDP2 = 1 :For 2000ms Time-out
WDP1 = 1 :For 2000ms Time-out
WDP0 = 1 :For 2000ms Time-out
// Enter Watchdog Con?guration mode:
WDTCSR |= (1<<WDCE) | (1<<WDE);
// Set Watchdog settings:
WDTCSR = (0<<WDIE) | (1<<WDE) | (0<<WDP3) | (1<<WDP2) | (1<<WDP1) | (1<<WDP0);
sei();
delay(100);
digitalWrite(13,LOW);
delay(100+loop_count);
loop_count=loop_count+100;
wdt_reset();
