Watchdog
I would like to use watchdog on my Arduino 101 board.
How can I do this ?
I tried to overwrite the function like due
void watchdogSetup(void) {
but it's not working. I am pretty sure it is cause the architecture is different.
Thanks
Did you ever get an answer for this? I'm looking for a watchdog for the 101 as well...
Nop,
But i guess you can set the watchdog with some assembly code.
I saw this post about watchdog timer.
I have a working example if anyone is still looking: https://github.com/leaubeau/wdt101/
leabeau: I have a working example if anyone is still looking: https://github.com/leaubeau/wdt101/
Do you know if your lib would work with an MKR ? Oh bugger it am going to try it anyway...EDIT guess not..Oh well and it looked like a nice short easy to use one too.
You are using the timer0 of the arc processor, that's mean you're using the timer use for the function millis() no ?
Then millis will not work anymore.
It is why I want to use the watchdog specialized timer on the x86 processor.
