Water, and electricity
with all the rain and warm temps, i thought i would check my basement workshop. Glad i did! the water is starting to creep across the floor! my server rack has a max of maybe 1.5 - 2 inches clearance, before the water gets into places i don't want it. i put a camera (water-resistant) on the situation though, so i can keep an eye on the water creeping.
I hate having my electronics shop and server rack down in the basement, but it is where it is, for now. when i can afford my own place, i hope that changes things.
i suppose i could rig up my alarm pager to alert of water level. it can't be too hard to make a water sensor. mount it a bit below the server rack max level.
~Travis
All you need is to pieces of metal and an arduino for the water sensor
What you need is a pump....
so put it outside...
Put the pump outside? How would that work?
well...where is the water coming from?
Submersible pumps with float switches are freely available. In the UK a firm called 'Hippo' are well known.
Allan
travis_farmer:
Hmm, everything on the web shows the use of an Op-Amp to boost the signal. i may try just sticking the pager wires right in the water. it has both negative and positive triggers. the negative trigger should be the best.
Use a piece of Veroboard (stripboard) with the strips vertical. Connect alternate strips to one wire and the other alternate strips to the other wire. A larger surface area (many strips) will make your detector more accurate.
Hi, mate.
If you were here and renting, the landlord would have to fix the problem.
Water in the basement would be classed as a health risk.
Tom.... :slight_smile: :o
G'dnight... :sleeping: :sleeping: :sleeping:
Spacex launch commencing in 40min but I can't stay awake.
If you have some space between your rack and the ceiling, consider getting a few bricks and raise the rack. That would buy you a few more inches next time.
