Water flow counter start in 0
Hi
I'm using a waterflow sensor to turn on/off relays. The pulses to turn on and off relays depends of wich button is pressed.
The problem is that the flow counter (contagem_total) have to start with value 0 and for some reason the counter is setting to 0 every second and cannot do counting.
Can someone help me detecting the problem? Thanks in advance.
#include <Math.h>
#include <Wire.h>
int pinbotao = analogRead(A0);
int rele_enchimento = 7;
int rele_fim = 3;
int rele_natural = 4;
int rele_fria = 5;
// conta litros
volatile int flow_frequency; // Measures flow sensor pulses
unsigned char flowsensor = 2; // Sensor Input
float contagem_total = 0;
//Variáveis
int last_saida = 0;
int last_fluxo = 0;
int fluxoA = 300;
int fluxoB = 1000;
int last_botao = 0;
void flow () // Interrupt function
  flow_frequency++;
  Serial.begin (9600);
  pinMode(rele_enchimento, OUTPUT);
  pinMode(rele_fim, OUTPUT);
  pinMode(rele_natural, OUTPUT);
  pinMode(rele_fria, OUTPUT);
  pinMode(flowsensor, INPUT);
  digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
  attachInterrupt(0, flow, RISING); // Setup Interrupt
  sei(); // Enable interrupts
  digitalWrite(rele_enchimento, LOW);
  digitalWrite(rele_fim, LOW);
  digitalWrite(rele_natural, LOW);
  digitalWrite(rele_fria, LOW);
  int botao = analogRead(A0);
  if (botao > 500)    {last_botao = 1;}
  if (botao > 300)    {last_botao = 2;}
  if (last_botao == 1) {
    contagem_total = 0;
 {   contagem_pulsos();
    if (contagem_total < fluxoA - 80) {
      digitalWrite(rele_enchimento, HIGH);
      digitalWrite(rele_natural, HIGH);
    else if (contagem_total < fluxoA) {
      digitalWrite(rele_fim, HIGH);
    else if (contagem_total == fluxoA || contagem_total < fluxoA) {
      last_botao = 0;
    if (last_botao == 2) {
    contagem_pulsos();
    if (contagem_total < fluxoB - 80) {
    else if (contagem_total < fluxoB) {
    else if (contagem_total == fluxoB || contagem_total < fluxoB) {
      last_botao = 0;
      contagem_total = 0;
  Serial.println(botao);
  Serial.println(contagem_total);
//contagem de litros
void contagem_pulsos() {
  contagem_total += flow_frequency;
  flow_frequency = 0; // Reset Counter
Your loop is running fast (which of course it should do)
The serial output should fill your screen quickly
I don't understand why this code sets to zero once a second.
You should use
attachInterrupt(digitalPinToInterrupt(flowsensor), flow, RISING);
to make sure that the right interrupt gets attached
for using an inputpin with internal pullup you code
  pinMode(flowsensor, INPUT_PULLUP);
and not
thre is one pair of curly brackets that are not needed
#include <Math.h>
#include <Wire.h>
int rele_fim = 3;
int rele_fria = 5;
// conta litros
//Variáveis
int last_saida = 0;
int last_fluxo = 0;
int fluxoA = 300;
int fluxoB = 1000;
int last_botao = 0;
void flow () { // Interrupt function
  flow_frequency++;
  if (botao > 500)    {
    last_botao = 1;
  if (botao > 300)    {
    last_botao = 2;
    contagem_total = 0;
    { contagem_pulsos(); // this curly bracket is too  much
        last_botao = 0;
    contagem_pulsos();
      last_botao = 0;
      contagem_total = 0;
best regards Stefan
